The 3 little clear stick-on stone shields at the lower back of the rear doors on the plastic body side molding are starting to get dirty around the edges. I have seen this on other cars that this dirt will continue to propagate under the clear plastic and look worse than anything the shields are suppose to protect from happening. Does anyone else have this problem? I don't suspect you would notice it on a dark colored car. Has anyone taken them off? If so what did you do and how did it turn out? My fear is that I will booger up the body side molding when I remove them.
