I just want to thank everyone that got involved in Genvibe's team on the World Community Grid!The stats are down right now, but should be back in a few minutes. Since I started up the team about two years ago, we have consistently placed below 280 in rank (as a team).That's 280 through all the teams in the world!Honestly, I think that's pretty darn good. I think as a team we've contributed about 10 years of computing power to the project. For those of you who don't know, the World Community Grid is similar to SETI@Home. It's 'distributed processing'.Basically, a research group (most recently, AIDS research and Genome classification) find computations that can be packed up and done in small bits across thousands of computers. If you leave your machine running with just a screensaver up or the monitor off, you can contribute! All you need to do is go to
http://www.worldcommunitygrid.com and find our team (genvibe.com) and sign up! You download a small application that will then run as your screensaver, and all that unused processor time will go to solving problems, such as 'Help Defeat Cancer', 'FightAIDS@Home', and others!You don't win prizes, you don't get anything out of it other than knowing that you're helping very good causes get closer to answers. You can take pride that you've helped in some small way by just letting them use processor time that would be otherwise wasted.For anyone worried about privacy, this does not open a back door on your system. The program contacts the server, gets its data to process, then processes. Once it's done, it uploads the finished results and gets more to chew on!C'mon, join the grid! It won't hurt, I promise!
