the cost of the unichip is almost as much as getting the powerfc if i find it at ebay, so i was just gonna get that and have my local guys change my lift as well as all the other numbers. but i dont know what will happen if i take it to get inspectedand if i have to swap it out, is it possible to save the map they built for my car so its 10 seconds away from being fun again
the pfc is not obd2 so you will not pass the e check. im pretty sure it will not lose its progam when you swap it out. but you can check http://www.newcelica.org for more info plenty guys are running the pfc and if you do a search im sure youll find your answers.
