I was just wondering what my options where for SR and CAI setups. I know K&N is the most popular name out there, but with my painful research experience, i have come across 2 different part numbers for the K&N setup, and very little for other manufacturers.What are1) Different manufacturers and cost (please list)K&NAFE2) Home made/DIY options - Rona/Home Depot-Vibrant PerformanceThanks
Welcome to GenVibe! You have an AWD with a cable throttle so you can pretty much choose from any intake available. You are able to get the same intake for the '03-'06 Vibe base & Vibe AWD, '03-'06 Matrix Base, Matrix XR & Matrix 4WD. This is only because the AWD has a cable throttle. So do searches for both the Vibe and the Matrix.Check out these other brands as well:http://www.cosmoracing.com $80-120 - best place: http://www.cosmoracing.com or Ebayhttp://www.Weapon-R.com $175 - best place: Ebayhttp://www.Injen.com: $200+ - best place: http://www.neverenoughauto.com or Ebayhttp://www.AEMpower.com: $150+ - best place: http://www.neverenoughauto.com or Ebayhttp://www.ebay.com - el-cheapo intake, thinner metal works great! - $40-$80 - Best place: http://www.ebay.comGood luck! Let us know that you choose.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
B-Crush, thanks for the info. Possible part #'s for the sites you have posted? Also, I heard/Read that the MAF sensor or something like that, was different bewteen the years of first production and presenst day. Also that it (the sensor) could not fit on the intake pipe, along with the intake not fitting to the pipe. k&n part #("S)69-8601 and 69-8600
Search those sites for applications for the Vibe. The MAF sensor has not changed. It will fit on all of the intake pipes that are made for our cars. Not sure where you are getting your that incorrect info from. It is smart of you to ask about it here on GenVibe though. Search for '03-'04 Vibe Base or Matrix XR as well as the '03-'06 Vibe AWD and Matrix XR 4WD.
My Fleet:
So the GT, and Base models have different Throttle bodies? Also, I have read on here that some have to "modify" the intake kit, or a hose leading to the engine.
Yes they are different. You will not have to modify yours since you have a cable throttle. The people modifying theirs have the electronic throttle. Those are the '05+ Base Vibes only (not AWD or GT)
My Fleet:
