Winter tires for a AWD Vibe
dcbridgwater
Post by dcbridgwater »
I have a 2006 AWD Vibe and after reading the posts for winter tires I have decided to get a set of 15" rims from a 2004 Corolla and have a set of 195/65R15 Michelin X-Ice tires mounted on them. I have not yet mounted them on the car. I was wondering if anyone thought I would have a problem with this set up. Also what air pressure are you using in the 15" tires? Should I use what is on the door sticker for stock 16's?Thank You for a great forum!!PS. I hope I did not mess this since it is my first post
2006 Neptune AWDSide & Curtain AirbagsABSPower Package
CAN-AWD-VIBE
Re: Winter tires for a AWD Vibe (dcbridgwater)
Post by CAN-AWD-VIBE »
Welcome to the forum!!!your tires should be no problem. if they fit and are close to the same size as stock you should be laughing.pull an e-brake or two for me and have fun CAN-AWD-VIBE
Raven
Post by Raven »
Welcome to Genvibe!That's the perfect set-up. Run 32psi. Rims should be $40.00 each and the tires about $81.00.
dcbridgwater
Thanks CAN-AWD-VIBE and Sunny for confirming that this was the correct setup. Now I just have to wait for winter!
trueimage
Post by trueimage »
hey, I have an 06 AWD Vibe and right now it has 205/55R16 all seasons on it, from the dealership.I am going to put steel rims and winter tires on it and I was thinking 15" rims with 195/65R15 as they are cheaper.Can I do this safely?Also, what are the numbers after these ie 91Q 95T 91H 91T 89S etc??Thanks very much. I am going to order these in today, as it is already snowing up here in Ft Mac.
zionzr2
Re: Winter tires for a AWD Vibe (trueimage)
Post by zionzr2 »
Quote, originally posted by trueimage »....Also, what are the numbers after these ie 91Q 95T 91H 91T 89S etc??Thanks very much. I am going to order these in today, as it is already snowing up here in Ft Mac.Theses are the speed ratings for the tires. I believe stock is 89 so you can go higher just not lower.AS far as the size change goes I belive that can and has been done safely!! Others will chime in and correct me if i am wrong. Drive safe! Happy Drifting!
CAN-AWD-VIBE
in kmph (this is rough but gets the idea)q=160 or 170s=180t=190h=210your 15s will work well... have a good time up there and try to stay warm
