After installing a sweet deck w/subwoofer controls, I think we all know what's next on the list (after I get a carpet for the rear, groceries are sliding everywhere8{).So my question is, does the factory alternator provide enough power for the electrical system with subs & an amp installed? I know everything will run, I just don't want to have to replace an alternator every 6 mos. Is a capacitor necessary?I am planning on going with about 400w amp and a really good dvc 10", or two lesser quality 10s.Thanks in advance for the help.
'04 Vibe 1.8VVT-i, K&N Typhoon S/R, Fullboar muffler w/3.5" resonator tip. Sony CDX-GT500 h/u + Fosgate mono amp w/2 10" woofers & cap. Tinted side rear windows, SilverStar headlights and Cool Blue fogs. DC Sports Headers. 2.5" stainless pipe from stock resonator to muffler. Limited 903's (17x7.5) Gunmetal Gray with 225/45/R17 Strata tires. Link to my photobucket videos: http://s100.photobucket.com/al...ideos/
I really doubt you will need to worry about the alt.Thats my setup power wise minus the M&T amp and I have a stock battery and alt still from when I got the car 2 years ago.Kinda cool to see there's another gen vibe person from my general area of Ohio.
Thanks for the info, KaoStarr. Do you have a charging wire going to the 2nd battery?BTW, yes Newton Falls is close to Warren. You will probably see (or hear) me cruising around at some point in the future.
I think my lights almost go out, within 20m i can kick the battery light on. But I think I need to replace my stock battery, its still the original, and I want another deep cycle under the hood
So I went with a Scosche kit that came w/a 500k capacitor. 325 watt Fosgate mono amp and no light dimmage. I do have two questions though.1. Will the little light on the capacitor wear down my battery? I know a cap holds a charge, but I have some doubts.2. When installing the main power wire, I had a heck of a time loosening the 90 degree bolt on the terminal and ended up accidentally twisting the lead battery post inside the battery8^{ I know this is not good, but the car starts fine. Should I replace the battery asap?
Quote, originally posted by mathteacher’04vibe »1. Will the little light on the capacitor wear down my battery? I know a cap holds a charge, but I have some doubts.it shouldn't Quote, originally posted by mathteacher’04vibe »2. When installing the main power wire, I had a heck of a time loosening the 90 degree bolt on the terminal and ended up accidentally twisting the lead battery post inside the battery8^{ I know this is not good, but the car starts fine. Should I replace the battery asap?yes. asap
