03 Alarm Wiring Guide
4azdmunky
Post by 4azdmunky »
Same thing, from the12volt.com. Not responsible if wrong.| ITEM | WIRE COLOR |POL| WIRE LOCATION || 12V|white & black |+ |ignition harness || STARTER|red |+ |ignition harness || SECOND STARTER| | | || IGNITION|black/yellow |+ |ignition harness || SECOND IGNITION|black/white |+ |ignition harness || THIRD IGNITION| | | || ACCESSORY|blue/red |+ |ignition harness || SECOND ACCESSORY| | | || POWER LOCK|green *1 |- |passenger kick panel || POWER UNLOCK|blue/black *1 |- |passenger kick panel || LOCK MOTOR|blue | |driver kick, door harness || UNLOCK MOTOR|red | |driver kick, door harness || DISARM DEFEAT|red | |driver kick, harness to rear|| PARKING LIGHTS +|green | |driver kick panel || PARKING LIGHTS -|green/white | |headlight switch || HEADLIGHTS|red |- |headlight switch || DOOR TRIGGER|red/yellow |- |driver kick panel || DOME SUPERVISION|comes on with unlock| | || TRUNK/HATCH PIN| | | || HOOD PIN| | | ||TRNK/HTCH RELEASE|blue/white |- |release switch on dash || FCTRY ALARM ARM| | | ||FCTRY ALRM DISARM| | | || DISARM NO UNLOCK| | | || TACHOMETER|*2 | |ignition coils || SPEED SENSE| | | || BRAKE WIRE|green/white |+ |brake pedal switch || HORN TRIGGER|green/white |- |steering column || WIPERS| | | ||Notes:*1 These are the passenger key cylinder wires. Meter the wires while turning the key in the passenger door. *2 Go to any one of the ignition coils under the black motor cover and use red/blue, yellow/green, gray, or white.
