Found this on the12volt.com. It is for the 05Matrix, but should work for us too. I do not know how accurate this is, so use at your own risk, I'm not responsible if anyone lets the magic smoke out of their equipment or car:12volts white (25A), black (15A) + ignition harnessStarter red + ignition harnessSecond Starter N/A Ignition black/white + ignition harnessSecond Ignition black/yellow + ignition harnessThird Ignition N/A Accessory blue/red + ignition harnessSecond Accessory N/A Keysense blue/black - ignition harnessNotes: Using the status output to trigger this wire during remote start will disarm the factory alarm without unlocking the doors.Power Lock green - driver kick, 10 pin plugNotes: Meter these wires while turning the key in the driver door key cylinder.Power Unlock blue/yellow (double pulse) - driver kick, 10 pin plugNotes: Meter these wires while turning the key in the driver door key cylinder.Can also use the passenger door key cylinder wire for unlock, which only requires a single pulse. It is blue/black (-) in the passenger kick in a 10 pin plug.Lock Motor blue 5wi driver kick, blue 12 pin plugUnlock Motor red 5wi driver kick, blue 12 pin plugParking Lights+ green + driver kick, harness to rearParking Lights- green/white - headlight switchHazards yellow/black - flasher relay left of fuse boxTurn Signal(L) green/black + flasher relay left of fuse boxTurn Signal(R) green/yellow + flasher relay left of fuse boxReverse Light red/black + front of fuse box, 10 pin plugDoor Trigger red/white - interior light switch on dashDome Supervision red/black - interior light switch on dashTrunk/Hatch Pin common with door trigger wire Hood Pin N/A Trunk/Hatch Release blue/white - release switch on dashPower Sliding Door N/A Factory Alarm Arm arms with lock Factory Alarm Disarm disarms with unlock Disarm No Unlock use key sense wire Tachometer black ac ECM, far right plug, pin 5Notes: The ECM (Engine Control Module) is behind the glove box.On the XRS models, the tach wire is in the second plug from the right, pin 3.Wait to start N/A Brake Wire green/white + brake pedal switchParking Brake red/black - parking brake switchHorn Trigger green/yellow - steering columnMemory Seat 1 N/A Memory Seat 2 N/A Memory Seat 3 N/A Immobilizer Bypass Module: Required: Yes Type: Transponder Part #: 556U or 555U
