ENGINE COVER REMOVAL HINTS
roddney1
Post by roddney1 »
I find that if you spray a little WD-40 around the plastic pins in the back of the engine shroud (or any plastic pins for that matter), and use a tack puller to lift under them, you can usually remove them without breaking them. A better solution for this situation is to replace the pins with 6mm hex bolts, as the back two holes are threaded the same as the front. That way the cover can be removed in the future much easier.
PONYAK TWO2004 Fusion Orange VibeMoon & Tunes, Autotrans, Power Package, Protection Package, Polished Steel Exhaust, Aluminum Wheels, Bumper Protector. ABS.Mods... Hella Horns, installed rear cargo carpeting.
mathteacher'04vibe
thanks, colors?
Post by mathteacher'04vibe »
Thanks for the tip. Does anyone know where to purchase new covers in various colors?
'04 Vibe 1.8VVT-i, K&N Typhoon S/R, Fullboar muffler w/3.5" resonator tip. Sony CDX-GT500 h/u + Fosgate mono amp w/2 10" woofers & cap. Tinted side rear windows, SilverStar headlights and Cool Blue fogs. DC Sports Headers. 2.5" stainless pipe from stock resonator to muffler. Limited 903's (17x7.5) Gunmetal Gray with 225/45/R17 Strata tires. Link to my photobucket videos: http://s100.photobucket.com/al...ideos/
NascarXprt
Re: thanks, colors? (mathteacher'04vibe)
Post by NascarXprt »
the cover you paint your self using a certan heat resitant paint.
My '04 Garage - My '06 Garage - My '09 GT Garage
November 2006 MOTM / February 2007 VOTM / April 2010 VOTM / June 2011 VOTM
Mrizzle05
Post by Mrizzle05 »
you can purchase CF covers!!! But they are pricey... like 160-ish or so for a trd one
engine111
Re: thanks, colors? (Mrizzle05)
Post by engine111 »
go to your local autozone, they will have heat resistant paint in ay color you can think of for like 5 bux a can
tcam
Re: thanks, colors? (engine111)
Post by tcam »
what is a "tack puller?
hakune
Post by hakune »
meh just run the engine for a while after you spray some wd-40 on just enough too heat the block up a little they should come right out
VforVIBE
Re: thanks, colors? (NascarXprt)
Post by VforVIBE »
Quote, originally posted by NascarXprt »the cover you paint your self using a certan heat resitant paint.Heat resitant paint, hehehe
“I live my life free of compromise, and step into the shadows without complaint or regret.”
Viva la Pontiac! 2009 Jet Black GT
roddney1
Re: thanks, colors? (silverawd26)
Post by roddney1 »
A tack puller looks like a small screwdriver with a "V" cut in the center. It's used to pull out thumb tacks. You can buy them at just about any hardware store
tcam
Re: thanks, colors? (roddney1)
Post by tcam »
ooo, ok. thanks. that'll help a lot
