Check engine light (CAI)
nuvibe
Post by nuvibe »
I installed a short ram on my ride and the check engine light came on a couple day's later, Help! Is this going to be an on going problem? or then I'll go back to stock...... nuvibe
Petrucci914
Re: Check engine light (nuvibe)
Post by Petrucci914 »
Make sure you that unhooked the battery after you installed it to reset the ECU. Then let the car idle for 10 minutes. You also want to make sure everything is connected correctly and tightened. Be careful of the MAF sensor because it's easily damageable and you may want to clean it.
2003 Pontiac Vibe Base - AutomaticTRD Supercharger w/ Smoothflow PulleyaFe Drop-in Filter - DC Sports HeaderFull 2.25" Exhaust -Magnaflow Catback + CatsOptima RedTop - Tru-Cool Tranny Cooler
nuvibe
Post by nuvibe »
Thank's for the info. Petrucci914; Should I reinstall the MAF again and go though the step by step.... nuvibe
northvibe
Post by northvibe »
yea take the negative off the battery for 10 min the plug back in. what SRI did you get? oiled filters can dirty the maf sensor and make it throw a CEL, you can try some MAF cleaner on the sensor.
2002sportside
Re: (northvibe)
Post by 2002sportside »
Make sure the MAF is in the right way too. That will cause a CEL. Do you know what the code is?
2005 Moonstone Base Vibe 38k as of October, 2010 (41k as of 7-15-11)Moon & Tunes, power package, automatic, center console power port added
goodvibe
Re: (2002sportside)
Post by goodvibe »
If you used an oil gauze filter, you may want to clean the MAF also before you reset.
nuvibe
Post by nuvibe »
Sorry for the late reply. MAF is clean so I'm going to double check every thing. Plus I called my brother and he helped me and went through some thing's with me to check also, he's a smog tech... nuvibe
