Ok so the SC is fully installed. It starts up fine with factory ECU.I plugged in the supplied TRD ECU and does not start. The car cranks, but will not start.Any ideas?BTW car is a 03 AUTO Corolla. I installed a GM supercharger with a GM auto ECU(still comes stamped as TRD).Things ruled out1) TRD ECU adapter (swapped with Warlords and still does not start)2) Wiring3) SC install (it starts up without TRD ECU)I am pretty lost and without a car right now haha. Any ideas as to what else to do or check?I do have a CEL, charging my PDA right now, so will go pull it up in a bit.NOW I need you SCed guys to do a favor, please check and tell me what the ECU part number is for auto and for manual!Ok I THINK I found the problem.The part number on the ECU box for auto Vibe is 00602-17620-127BUT!!!! On my ECU the number s 00602-17620-132!I am trying to find some info, I THINK I have the wrong ECU, perhaps the 5speed ECU?
I cannot find part numbers, I can find TRD numbers, but not for vibe. If you guys who have it could please post the P/N off your ECU I would really appreciate it. Also if someone has an auto ECU they are willing to send out, let me know!Thanks!
I'll go check mine (auto) and get the P/N for you. BRBEdit, back! I have a GM plate. Also, the part number on my ECU is 00602-17620-132. You have the right ECU for an auto as far as I know, and mine has been running with it for quite some time now. I had the same problem and it was the adapter, but you said you swapped it for a working adapter, so not sure on that. Not sure what it could be, but if it works without the ECU it must be wiring somewhere.
I think if it was a MAF it would be gone with or without the TRD ECU. This one is confusing, nut so was mine when the ECU adapter went out. I had to bust it open practically to find 2 wire runs melted off the board! Did you swap the TRD ECU wiring harness as well. Sounds like a very good possibility if the adapter didn't pan out. If you have a local buddy with a set-up, do like Phil and I did and swap it all both ways. Take your ECU, harness, and adapter and put it in his car and see if it starts. If not, work your way down until you find the problem. Know that it may take a few tries before the car will start again if it is one of these problems.
Quote, originally posted by yeye »I see the problem is, my friend has a 5speed SCed Corolla and I have an Auto Corolla :-/.BUT I can try my ECU adapter in his car, just not the ECU.Prob not, I assume the wiring and adapter could be different, but I am not sure on that.
I had the Unichip already, but I tried the TRD ECU just for S&G's. It didn't work the first time. Then after a couple months I figured out that I had it wired wrong. Used the long red wire instead of the short red wire. Or something like that. I just didn't have power going to the piggy back ecu.
IC, thanks for the info! I am pretty sure we have the right wire connected. Can check again tomo. Thing is I went over wiring and then my friend did as well.
Quote, originally posted by yeye »Haha this guy! Yes I think it is the ECU, going to have GM test it.Don't be surprised if they can't, you're better off going to Toyota.
Quote, originally posted by yeye »Really? Would a Toyota Dealership test it?I talked to a GM performance dealership and they said they would.Well, if you found someone that will then that's awesome. Allof the Pontiac dealers around here didn't have the knowledge or tools to do anything with the S/C. You could always call a Toyota dealer first, especially if you are paying for it. GM tends to overcharge by quite a bit!
Quote, originally posted by yeye »Called and Toyota dealership cant test it :-/.That's new! In San Diego all the Toyota dealers were more than welcome to help with it, but all the Pontiac dealers said no way! Let us know what happens!
Yes well as of right now cannot find a dealer who can test my TRD piggyback. Be it Toyota or GM :-/.I am going to try to send it to someone who has an auto supercharged car to test it perhaps?
Quote, originally posted by warlord »I helped yeye intall the emanage and it started right up. So far so good.It def was a bad piggyback.Great news, thanks for keeping us posted!
