O/D button broken wire
DarkShocker
Post by DarkShocker »
Well i had a light go out in my Heater / Ac control area so i was going to change it well i decided i need to take the shift knob off and not even thinking i ripped the wire that hook up to the O/D button right out one i sheared right off and the other only the terminal ripped out of the switch but the other wire its toast. HOW CAN I FIX THIS ???
RePo
Re: O/D button broken wire (DarkShocker)
Post by RePo »
I did the exact same thing while replacing the bulb that lights the gear indicator. I had to take the O/D switch out of the shifter and bring it into the workbench. I soldered some small guage wire (24 guage from cat5 ethernet) directly into the O/D switch and made it long enough for the handle to be removed without straining the wire. I'd classify that as a poor design. Just changing a bulb became a huge project.
I would love to change the world, but they won't give me the source code
DarkShocker
Re: O/D button broken wire (RePo)
Yeah i was thinking on doing just that but i wasent sure if it would work. Well I guess when i have the nerve to attempt to change the bulb finally i will fix the o/d button at the same time.Thanks for the Input
