Has anyone installed sidemarker bulbs?
CAN-AWD-VIBE
Post by CAN-AWD-VIBE »
Looks like there is a decent area to install sidemarker lights on the front fenders... has anyone done this?If you have how did you wire it so that they flash with the signal lights... do I just tie into the power wire at the front signals?CAN-AWD-VIBE
jwalcik
Re: Has anyone installed sidemarker bulbs? (CAN-AWD-VIBE)
Post by jwalcik »
i've seen this done on other vehicles, but i can't think of anyone in particular who's done it on their vibe. i know several folks over at nissanfrontier.net that have done it on the 1st generation frontiers. some used salvaged marker lights from a VW, others went aftermarket. then they just tapped into either their parking lights/turn signals. i've got a feeling somebody around here will have the wiring diagram for the existing lights handy...
2005 vibe gt
ToolGuy
Post by ToolGuy »
I once had only one from an export Cavalier, still have it too. However the hole for it in the fender was not circular or square it was a combination of cuts to hold the assembly.Rather then cut up your fenders I would install them under the door mirrors or search for LED blinker door mirrors, not the same idea but close.
Celtic_Curse
Post by Celtic_Curse »
I have the sidemarkers installed and yes you just tie into the wire for the front turn signals. Although there are two wires one set will leave them on when the lights are on or if you want the signal peice of it attach it to the second wire. I have mine wired as signals and not on all the time. Hope that helps.
2003 Supercharged 5spd Vibe BaseGM Supercharger + TRD ECUMagnaflow Cat Back + DC Sports Header 18" AXIS rimms w/Kumho TiresTop Spoiler + Vis CF Functional Scoop
NascarXprt
Re: (Celtic_Curse)
Post by NascarXprt »
do you have a pic???
My '04 Garage - My '06 Garage - My '09 GT Garage
November 2006 MOTM / February 2007 VOTM / April 2010 VOTM / June 2011 VOTM
Celtic_Curse
yes I'll post when possible.
Celtic_Curse
Re: (NascarXprt)
Here you go.
jpalmer
Post by jpalmer »
that looks pretty good actually, i wasn't sure if I'd like that or not.another possible future mod I'll have to consider.
Oh yeah...did I mention I am a professional photographer? This is my website
CAN-AWD-VIBE
Re: (Celtic_Curse)
nice look and good tips thanks CelticCAN-AWD-VIBE
