Torque setting for axle shaft nut
Sabrina
Post by Sabrina »
Can anyone please tell me the proper torque setting for the axle shaft nut?Also, if you happen to know the correct size of socket for the job I would appreciate that information as well.Thank you,Sabrina
2002sportside
Re: Torque setting for axle shaft nut (Sabrina)
Post by 2002sportside »
Axle nut is 159 ft lb. You should replace it once you take it off, nuts are only designed to be used once. The original Toyota part # is 90177-22001. It was superceded by 90080-17238. I don't know the size or the Pontiac number though...
2005 Moonstone Base Vibe 38k as of October, 2010 (41k as of 7-15-11)Moon & Tunes, power package, automatic, center console power port added
