Need Door Hinge Part
Pontiac, GM SPO (Service Parts Organization) & TRD (Toyota Racing Development) discussions
Petrucci914
Post by Petrucci914 »
I don't know what the exact name is. My door flew open on a windy day and bend the hinge and broke some plastic. Now when I shut my door with the window down it rubs on the window. See picture
2003 Pontiac Vibe Base - AutomaticTRD Supercharger w/ Smoothflow PulleyaFe Drop-in Filter - DC Sports HeaderFull 2.25" Exhaust -Magnaflow Catback + CatsOptima RedTop - Tru-Cool Tranny Cooler
northvibe
Post by northvibe »
junk yard is the only place i can think of for just getting that part. or there was someone here parting out a vibe....
scherry2
Re: Need Door Hinge Part (Petrucci914)
Post by scherry2 »
its a check strap or link. dealer should be able to order you one. I think that is the part that causes the window problems people were reporting. you might want to tell the dealer your window pops once in a while. he might relace it for free.
Re: Need Door Hinge Part (scherry2)
Yeah, I'd milk that one if possible. GM should know by now those pieces are crap, so if the car is under warranty, get it fixed for free. Otherwise, the new and improved door check part numbers:$87.40 GM listLF: 88937010RF: 88937009
Image Image
Petrucci914
Re: Need Door Hinge Part (ColonelPanic)
No, way out of warranty. Know of a good place to get a good price on both? I found one place charging 54 a piece, just wondering if there are cheaper sources. Thanks!
scherry2
Post by scherry2 »
its not a warranty Item it is a T.S.B. technical service bulletin i would tell the dealer you have a popping noise coming from your window and that you hear that there is a T.S.B. concerning the check link and window breakage.
tnpartsguy
Post by tnpartsguy »
I might have a pair of them at work. let me check, it will be tomarrow before I can get back to you. Which one do you need?
Petrucci914
Re: Need Door Hinge Part (tnpartsguy)
Ya, if I could get them for both the front doors that'd be awesome. The left front is the one that's bad now but I have to take the right front door apart to tighten that loose bolt so I myswell replace the part with the updated one. They're the updated ones, right? Thanks!
tnpartsguy
$49 each, plus shipping is the best I can do. And I do have both in stock of the new design.
Petrucci914
How much would shipping be to Wisconsin. Zip-code 54155-9110. Thanks!
Petrucci914
I'll take both of them. LF and RF.
Petrucci914
Just a correction on the part numbers. They areDriver: 88973010Passenger: 88973009NOT 88937....
ProtonXX
Post by ProtonXX »
I have 2 used ones but the screws are stripped, I thought replacing them would fix the window rub problem and it didnt
