How to turn your automatic Base into automatic GT
NewNeptune
Post by NewNeptune »
Not really, but I've found that turning off O/D on the highway right before making a pass helps a lot. Sure better than waiting for the auto slushbox to decide to downshift.
2006 Pontiac Vibe Base, Automatic, Power PackageSony CDX-GT300Upgraded Horns
BlueCrush
Re: How to turn your automatic Base into automatic GT (NewNeptune)
Post by BlueCrush »
LoL! Funny!
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
Merzbow
Post by Merzbow »
(removed)...I wouldn't turn it off over 70mph though lol...otherwise you'd be runnin close to 5 or 6 grand! pretty soon a little computer screen will pop-up and say "WARNING: DANGER TO MANIFOLD" just before you jam your finger into the second NOS button...oh wait....
http://www.cardomain.com/ride/541918-1999 Infiniti Q45t-2003 base Vibe (Rest in peace my love)-2002 Ducati Monster 620 Dark
zionzr2
Post by zionzr2 »
Common practice for me on the little 2 lane roads.Except I mainly have been on the big 4 Lane jobs latley.
NascarXprt
Re: (zionzr2)
Post by NascarXprt »
thats how i did it and its fun hearing the engine and seeing peoples faces as i go by :D
My '04 Garage - My '06 Garage - My '09 GT Garage
November 2006 MOTM / February 2007 VOTM / April 2010 VOTM / June 2011 VOTM
NewNeptune
Re: How to turn your automatic Base into automatic GT (Merzbow)
Quote, originally posted by Merzbow »(removed)...I wouldn't turn it off over 70mph though lol...otherwise you'd be runnin close to 5 or 6 grand! pretty soon a little computer screen will pop-up and say "WARNING: DANGER TO MANIFOLD" just before you jam your finger into the second NOS button...oh wait....Over 70 MPH is when it is most useful. I get tired of being stuck behind people that speed up when I try to pass, so I just hit the button instead of waiting for the auto to do it as I move my foot to the floor. Makes an awful amount of racket though, so I only do it when I have to.
GrayFox
Post by GrayFox »
Quote, originally posted by NewNeptune »...turning off O/D on the highway right before making a pass helps a lot. Sure better than waiting for the auto slushbox to decide to downshift. lol, not quite a GT but its the closest a vibe will get to a paddle shifter
drunkenmaxx
Post by drunkenmaxx »
Quote, originally posted by Merzbow »(removed)...I wouldn't turn it off over 70mph though lol...otherwise you'd be runnin close to 5 or 6 grand! .nah, it would be around 3.5 to 4, i used to do it all the time.
MRCN RCE
Post by MRCN RCE »
turnin off the a/c helps too
GENVIBE: THE PLACE WHERE ALL THE COOL KIDS HANG OUT05 GTK&N SRI, exedy clutch, fidanza flywheel, Neo-GensLIFT: the equivalent of viagra for your tach n speedomy garagehttp://forums.genvibe.com/zerothread?id=24931
goodvibe
Post by goodvibe »
I used to drop the GT into third. Instant lift. There used to be devices that would turn off the AC compressor automatically when you putyour foot in it.
isaaclud
Re: (goodvibe)
Post by isaaclud »
How to turn your automatic Base into automatic GTin other words...I wish I my car was stick....but for whatever reason....its not! so make do the only way i canhaha
PEACEISAAC
GrayFox
Re: (isaaclud)
Post by GrayFox »
w/ the OD off going 75 i was running about 4200 RPMs last night...I wish mine was a standard, too. But then my wife couldn't drive (wait... is that such a bad thing )
lexicon
So, are there significant ill effects if you click OD button at highway speeds?
Post by lexicon »
I have to assume this is not a great thing for stress on stuff.Yes?Also, is anyone using anything in the Auto Tranny OTHER than Toyota fluid ?
2005 VibeAutomaticStockNon AWD125 hp model
GrayFox
Re: So, are there significant ill effects if you click OD button at highway speeds? (lexicon)
Post by GrayFox »
not using the OD makes your engine work harder by keeping it in 3rd gear. So in a sense, yes it is more stressful. But if you go to pass someone and floor it, it shifts down to 3rd anyway and once you let off it returns to 4th gear. As long as your don't have your foot on the floor all the time or drive around with the OD off it shouldn't cause any excesive wear & tear (no more than usual anyway)
scherry2
Re: So, are there significant ill effects if you click OD button at highway speeds? (ANO_Vibe)
Post by scherry2 »
your just going to quit using overdrive is all if you turn it off. will it hurt? no. cars back in the seventys never had o/d at all. "Overdrive" is the term for gear ratios that are lower than 1:1 – a situation where the engine is turning slower than the drive shaft. Overdrive gears are appropriate when very little torque is needed – the vehicle is no longer accelerating – and can deliver the best fuel economy. The six-speed transmission in the Ford Five Hundred has two overdrive gears, with a final ratio of 0.686:1.here is another thread on the topichttp://forums.genvibe.com/zerothread?id=15765
jake75
Post by jake75 »
Quote, originally posted by Merzbow »(removed)...I wouldn't turn it off over 70mph though lol...otherwise you'd be runnin close to 5 or 6 grand! pretty soon a little computer screen will pop-up and say "WARNING: DANGER TO MANIFOLD" just before you jam your finger into the second NOS button...oh wait....If you are already going over 70, what are you passing for?
NewNeptune
Because I'm trying to go 75, I get behind someone going 60-65 (and can't hold a consistent speed) so when I do go to pass I have to get up to 80 just to get around because they speed up when I try to pass.
