Just wanted to post this b/c I had a similar problem to others where my antenna was ripped out of the base in a car wash. At the time I didn't know anything and the antenna was dangling, so I cut the wire right at the base piece to get the antenna down since it wouldn't push back in. Here are some pics of the inside of the antenna. I did this a few weeks ago, just got around to posting the pics. I took down the headliner, removed the bottom nut for the antenna base from the inside of the car, and pulled the antenna up from the outside. Then I took out the few screws holding the base pieces together to get to the inside to see how I could fix it. I didn't have a soldering iron, so I just stripped the wire, bent it up towards the base, and put it back together. Now my singal is back and I can listen to the radio again!
