Is this normal? When I have my A/C on my idle is quite high, usually around 1600. If I turn my A/C off it goes down to 800. The same happens when I use the fan without A/C. Only difference is the idle stays around 1200 and then goes to 800 when I turn it off.
2006 Vibe (base) - Platinum Silver, 5 spd, ABS, Power Package, Infinity Speakers, Dynomax muffler, Cosmo SR intake - SOLD
While i'm not exactly sure of the numbers it is normal that A/C use will cause the Rpms to be higher at idle.It takes more power to turn the compressor motor than when its off.
