Painting Brake Calipers
tcam
Post by tcam »
Is it a necessity to sand the caliper before painting it? I have read a few posts on here that people recommend it, but my paint kit doesn't say anything about doing that. And for those that have done this mod already, how far back did u paint the caliper? Like did u paint the entire thing as much as you could. Or did u stop at the point where the paint would just be no longer visible?
VforVIBE
Re: Painting Brake Calipers (tcam)
Post by VforVIBE »
I didn't sand my calipers and they turned out fine, I use two coats thatt pretty much covered it. I did mine a week ago.http://forums.genvibe.com/zerothread?id=24797
“I live my life free of compromise, and step into the shadows without complaint or regret.”
Viva la Pontiac! 2009 Jet Black GT
tcam
Re: Painting Brake Calipers (VforVIBE)
Post by tcam »
yeah, I remember seeing that post not long ago. And I have had this caliper paint for a while now, and ur post kinda inspired me to get 'em painted soon. lolSo, did u paint the whole caliper, or just the parts that are visible from the outside?
VforVIBE
Post by VforVIBE »
I painted as much as i could which was mostly all of it. Do you plan on painting the drums too?
LUVROK
Post by LUVROK »
Being that they're cast aluminum and have a rough surface, sanding won't do much. I would spray them down with brake parts or carb cleaner and brush them clean prior to painting though. Paint prep products may not be good for the seals, the parts cleaner may not be either so just watch those areas.
2005 GT, Neptune, Injen CAI, Magnaflow Catback Exhaust, Eibach Sportline Springs, Progress Rear Swaybar, DC Sports Strut Tower Bar, Tow package
tcam
Re: Painting Brake Calipers (LUVROK)
Post by tcam »
Quote, originally posted by VforVIBE »I painted as much as i could which was mostly all of it. Do you plan on painting the drums too?I have calipers on both front and rear wheels.Quote, originally posted by LUVROK »Being that they're cast aluminum and have a rough surface, sanding won't do much. I would spray them down with brake parts or carb cleaner and brush them clean prior to painting though. Paint prep products may not be good for the seals, the parts cleaner may not be either so just watch those areas.will do
