Crankcase Fliter and Oil Spray
skylinedrifter
Post by skylinedrifter »
On my 93 Saturn SC2, I installed an intake very similar to the K&N Typhoon SR for the Vibe. It didn't come with a crankcase filter, but I put one on and capped the hole in the intake. After a few weeks, I noticed oil residue all over the place, and the crankcase filter was the culprit.Is the Typhoon SR setup the same way, whereby there is a hose running to the intake or does the crankcase hose need to be filtered seperately? If seperately, has anyone else here had that experience with their Vibe? I'm debating if the meager HP gains from rerouting the hose to it's own filter versus the pain in the (removed) of cleaning up that garbage every month or two.Thanks!
coldmm803
Re: Crankcase Fliter and Oil Spray (skylinedrifter)
Post by coldmm803 »
check out this thread, not sure if it helps answer your questionhttp://forums.genvibe.com/zerothread?id=24278here is a breather filter from weapon rhttp://www.weapon-r.com/cgi-bi...arch2
skylinedrifter
Re: Crankcase Fliter and Oil Spray (coldmm803)
I read that one but it doesn't make any reference to oil spray. If I were to make an assumption, it would be that the Vibe won't have that sort of a problem. I guess I am just looking for some confirmation one way or another.
