Quote, originally posted by 4X4CHICHI »are you gonna make it functional?yeah, except I thought these hoods were all built functional. But I guess not lolIt looks great though
Quote, originally posted by joholste »They are all built functional... but you have to hook them up to make them functional.ohhhh ok. thnx for letting us know. I was curious because I was pretty sure that I had heard them being functional before.
yes i do plan to make it into an actually hooked up Ram Air Hood... here's the plan... i will get the SR intake and then put one of the K&N filters that has an intake cone on the inside of the end of the filter as well and hook that up with a rubber hose....however the plan could change.this is the only one i can find that is similar to what i want:http://www.knfilters.com/searc...-4990
2003 Chevy Silverado Ext. Cab, Z71Formerly2003 Base Vibe (Frosty)
nice I'm trying to decide on a hood that has some style and function but not biting anyone...like lancer on damonjr...hard though..ur hood looks the tiight!
- VORTECH SUPERCHARGER- GREDDY E-MANAGE BLUE- MSD IGNITION MAP SENSOR- RSM RACING CUSTOM FRONT STRUT TOWER BRACE - RSM RACING CUSTOM CAT BACK EXHAUST - RSM RACING CUSTOM BIG BRAKE KIT- B&G LOWERING SPRINGS - ENKEI 18" RSV GUN METAL ROLLERS MACHINED LIP - SIRIUS SATTELLITE RADIO- ALPINE IVA-W200 2-DIN DVD/CD/AV Head Unit - ALPINE REAR FLIP DOWN MONITOR
the filter and ductwork is extra... go figure.. plus you still have to cut a hole in the top of your factory airbox.
Quote, originally posted by satur9 »the filter and ductwork is extra... go figure.. plus you still have to cut a hole in the top of your factory airbox.so if u already have a short ram air intake installed, do u have to re-assemble the stock air-box?
The hood looks great, but I gotta say the fit is terrible - tight to the right and wide gaps on the left (driver's side). Correct this and you have a sweet looking car.
easier said than done my main problem is the fact that the pins have become slightly unaligned and aren't holding a steady position...and i've already painted and drilled holes..... and the poopy heads didn't remove the metal disks to paint the hood
