2" spacer
scherry2
2" spacer
Post by scherry2 »
I bought (from Damronjr I think, my minds going with age. so forgive me) some 2" spacers for my rear rims a few years ago. but I've never taken a picture of them. personally i like the way they fill the lip in the rear.
damronjr
Re: 2" spacer (scherry2)
Post by damronjr »
Yep, and looks good!
Merzbow
Post by Merzbow »
I allways wondered about that in the back. I think it looks alot better.
http://www.cardomain.com/ride/541918-1999 Infiniti Q45t-2003 base Vibe (Rest in peace my love)-2002 Ducati Monster 620 Dark
northvibe
Post by northvibe »
post more pics of different angles
SuperSpeedWagon
Re: (northvibe)
Post by SuperSpeedWagon »
it does look good me likey hahah
2010 vibe gt
scherry2
Re: (northvibe)
Post by scherry2 »
will do. I just got a new nikon coolpics L3. it will give me a chance to play with it.
northvibe
Post by northvibe »
i just noticed this on my car! i need some . so do they go behind the rim or behind the rotor thingy that hold the studs.
scherry2
Re: (northvibe)
Post by scherry2 »
between the drum and rim
zionzr2
Post by zionzr2 »
forgive my ignorance here, but is this device moving the wheels out 2" from their stock postion? Effectively making your Wheel base 4 inches wider?
northvibe
Post by northvibe »
so if its between the drum and rim...do you need longer studs?
damronjr
Re: (northvibe)
Post by damronjr »
Quote, originally posted by northvibe »so if its between the drum and rim...do you need longer studs?No, that's why they are generally not recommended, same as adapters. You just have to keep an eye on them and make sure they stay tight, but no difference from lug nuts. If you tighten them right, they should be just fine.
scherry2
Re: (zionzr2)
Post by scherry2 »
Quote, originally posted by zionzr2 »forgive my ignorance here, but is this device moving the wheels out 2" from their stock postion? Effectively making your Wheel base 4 inches wider?yesQuote, originally posted by northvibe »so if its between the drum and rim...do you need longer studs?no the spacer bolts to the oem studs with lug nuts and the rim is secured to the spacer studs with oem lugnuts.
northvibe
Post by northvibe »
OHH scherry2 if ou ever take off a rim again, could you snap a pic of that?damron or scherry2 - where do you get these and what brand?
damronjr
Re: (northvibe)
Post by damronjr »
Quote, originally posted by northvibe »OHH scherry2 if ou ever take off a rim again, could you snap a pic of that?damron or scherry2 - where do you get these and what brand?I got them from Ebay. Honestly, I have no clue who the seller was. I have a pic of them on my Vibe when I tried them out, but with the rims I have they stuck out too far. They seem to be perfect with the OEM 16's. I'll find the pic(s) and post it/them.Edit: Found them!
scherry2
Post by scherry2 »
there ya go. I still think I'll takes some pics.
2006Vibe
Re: (zionzr2)
Post by 2006Vibe »
Quote, originally posted by zionzr2 »forgive my ignorance here, but is this device moving the wheels out 2" from their stock postion? Effectively making your Wheel base 4 inches wider?You aren't increasing the wheel base, you're increasing the track width (cross car). The wheel base is the hub centerline relationship between the front and rear hub on the same side... that you can't "easily" increase.. unless you make your vibe into a limo
2006 Vibe 5 spd FWD - Abyss(Canadian model)Factory 16" Aluminum wheelsPower PackageGraphite Interior
northvibe
Post by northvibe »
wow that looks good, mods...aaahhh why do mods cost money! hahahha did you guys notice any handling differences after putting the spacers on?
scherry2
Re: (northvibe)
Post by scherry2 »
I didn't feel any difference.I take them off in the winter so I don't know if there would be a problem in the snow.
damronjr
Re: (northvibe)
Post by damronjr »
Quote, originally posted by northvibe »wow that looks good, mods...aaahhh why do mods cost money! hahahha did you guys notice any handling differences after putting the spacers on?On mine the tires scraped the lip of the fender! lol Didn't keep them on very long!
scherry2
Re: (damronjr)
Post by scherry2 »
was that because of your rims or Air Bags.
damronjr
Re: (scherry2)
Post by damronjr »
Quote, originally posted by scherry2 »was that because of your rims or Air Bags. The tires and the rims were too wide. I didn't have air-bags yet, just springs. It was lowered, and that also played a part, but if the rim/tire combo would have been thinner it wouldn't have rubbed like that anyways.
