hmmmmm
coratz
hmmmmm
Post by coratz »
Document ID# 1254244 2003 Pontiac Vibe - FWD --------------------------------------------------------------------------------Info - Pre-Delivery Inspection (PDI) #03-00-89-004 - (03/03/2003)Pre-Delivery Inspection (PDI)2003 Pontiac VibePDI ConcernsBelow are three specific areas that need to be emphasized due to recognized concerns on delivered vehicles. These items are either unique to this vehicle or have significant impact on initial customer satisfaction.Automatic Transmission Shift Interlock (ATSI) CoverYou will find a plastic cap taped to the shifter handle upon delivery of these vehicles to your dealership. This round cap is provided to cover the ATSI override control. The ATSI override is found on the transmission shifter bezel to the right of the shifter. To assure the complete safety and integrity of this system, you MUST install the included cap. To do so, simply insert the cap into the hole until seated.Vehicle Transportation Tie-Down Underbody Inserts There are two holes located in the vehicle underbody in front of the rear wheels (one hole each side) that are utilized for securing the vehicle during transportation. Two rubber plugs (found in the instrument panel compartment) are included with the vehicle to seal these holes in the underbody. You must install these caps to prevent water intrusion into the unibody which may cause excessive corrosion. Refer to the graphic above, which illustrates the passenger side of the vehicle (driver's side similar). The dark arrow indicates the position of the underbody cutout and the outlined arrow indicates the front of vehicle.Tire PressureImportantTires MUST be set to the recommended inflation pressure during the PRE-DELIVERY INSPECTION (including the spare tire).With the increased visibility and concerns over automotive tires in the media, it is more important than ever to properly check and adjust tire pressures (including spare). Improper tire pressures may result in ride, handling, and/or noise concerns. You MUST check and adjust the tire pressures during the pre-delivery inspection to the requested PSI as found on the tire placard, NOT the pressure indicated on the sidewall of the tire. The recommended tire pressure placard is located on the instrument panel compartment door. General Motors vehicles are shipped from the factory with tire pressures from 35 psi to 41 psi. Tire pressures are set higher at the assembly plants to assure proper tire bead seating. GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information. WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION © Copyright General Motors Corporation. All Rights Reserved. -------------------------------------------------------------------------------- Document ID# 1254244 2003 Pontiac Vibe - FWD
Sub-Vibe-R
Re: hmmmmm (coratz)
Post by Sub-Vibe-R »
Strange GM has to notify his dealer with those facts. It looks like some people complain about this. It is a good news for everyone who does not have his Vibe yet.
Frosty
Re: hmmmmm (coratz)
Post by Frosty »
Good catch! Can you provide the graphic for what we are looking for by the front wheels?
Frosty 5 speed Vibe Power & Safety Packages. Naturally Aspirated my gallery
Lorin
Re: hmmmmm (Frosty)
Post by Lorin »
Yes - need the graphic - I'm concerned about the front plugs they are talking about. They use lots of road salt in PA, plus, the fact that my tires were delivered at 40 psi indicates a lake of attentiveness on the part of the dealer.
Lorin2003 Pontiac Vibe GT, Neptune-mono, moons & tunes, power package, side impact airbags, rear seat covers, bumper protector, cargo mat.Mods installed: TRD exhaust, TRD stb, Mods removed: TRD CAI - annoyed by CEL
NSimkins
Global Moderator
Re: hmmmmm
Post by NSimkins »
FYI, to prevent any further confusion, if you re-read the portion about the Underbody Inserts, you will see that they are located "in the vehicle underbody in front of the rear wheels".Attached is the missing image.
meathead333
Re: hmmmmm (coratz)
Post by meathead333 »
whered you get this from??
My myspace.com profile My 73' Bronco Cardomain page
pmh013
Re: hmmmmm (meathead333)
Post by pmh013 »
quote:whered you get this from??Yes, I'd like to know that too. This one says Vibe FWD, is there one for the AWD too?
2003 Satellite AWD Two Tone, traded off at 180,126 kmNow the (fourth) catalytic converter is someone else's problem Now driving a 2007 Dodge Grand Caravan
NSimkins
Global Moderator
Re: hmmmmm (pmh013)
Post by NSimkins »
quote:This one says Vibe FWD, is there one for the AWD too?Yes, it applies to all models.Also, I just checked my Vibe and I do have the rubber grommets/plugs installed as indicated in the document/image.
bellwilliam
Re: hmmmmm (NSimkins)
Post by bellwilliam »
mine is definetely not installed, because the 2 rubber plugs are in my glove compartment.where are the holes exactly? I looked at the jpeg image, but can't really figure it out, is it just front of the rear wheels?
Bellwilliam2003 S/C VibeTrim : Base, Abyss , AutoOptions: Moon & Tunes, Power Upgrades: Supercharger, Split Second A/F controller, 225/45-17, My other cars are PTE Miata, 13 Tesla S, 13 Volt, 06 997
NSimkins
Global Moderator
Re: hmmmmm (bellwilliam)
Post by NSimkins »
quote:where are the holes exactly? I looked at the jpeg image, but can't really figure it out, is it just front of the rear wheels?Best thing to do would be to first print out a copy of the photo for reference. To make it simple, start by looking under the vehicle starting at the rear door (not hatch) and move back towards the rear wheel. You will see the spot pictured in the photo where the rubber plugs are supposed to be. They are not too far under the vehicle and can be seen by kneeling down and looking under.This is a simple 1-minute complete install.. no need to take this to a dealer unless you feel necessary.
NovaResource
Post by NovaResource »
I checked this morning and both mine are there. If yours aren't and you have the plugs, it would be an easy install using the image NSimkins attached. Like putting on a tupperware lid.
Sub-Vibe-R
Re: hmmmmm (NovaResource)
Under body plug are here as well and as told Nova, looks very easy to do it yourself.
Frosty
Post by Frosty »
quote:FYI, to prevent any further confusion, if you re-read the portion about the Underbody Inserts, you will see that they are located "in the vehicle underbody in front of the rear wheels".Sorry my fault. Must have been distracted
bellwilliam
thanks. that was easy.bellwilliam
pmh013
Post by pmh013 »
I just checked mine, and I have the plugs in place. You really need to get low to the ground to see them -- my hair was sitting on my very dirty garage floor to get down that low -- YUCK!However, I don't have my cover for the ATSI, so maybe I'll get that ordered in. Should take about a billion years for my dealer to get that in.
Info - Pre-Delivery Inspection document
Would be interesting to see if the 2005 pre-delivery inspection document has changed much. Does anybody here have access to it?
Mavrik
Re: Info - Pre-Delivery Inspection document (joatmon)
Post by Mavrik »
Its still the same.
21Rouge
Post by 21Rouge »
Quote, originally posted by joatmon »Would be interesting to see if the 2005 pre-delivery inspection document has changed much. Does anybody here have access to it?What about when the purchaser comes to pick up the vehicle? It is easy to be excited about this clean and new and expensive purchase. We just want to take the keys and leave as soon as possible. However to give us a focus before taking official possession could you recommend some organized check list for the buyer to go over re the delivered car before one signs off?
Re: Info - Pre-Delivery Inspection document (Boxgrover)
Quote, originally posted by Boxgrover »What about when the purchaser comes to pick up the vehicle? There is some info in http://forums.genvibe.com/zerothread?id=5216 - "advice for new owner" thread, but I don't think anyone has posted anything organized as a buyer inspection checklist. That would be a good thing to have though.
Mavrik
Post by Mavrik »
Well don't just pick up your keys and leave, make sure the salesman gives you a nice good long walkthrough on everything about your car. But there is no inspection sheet or such outside the pre-delivery inspection which is done on every vehicle when it gets unloaded off the truck regardless if its sold or not. If you want to take the time and go over the vehicle before you leave with it however, is not a bad idea. make sure everything works before you leave.
AKLGT
Post by AKLGT »
this is my seventh vehicle. i NEVER leave the dealership without doing a walk through. if you do, then that's your own fault. atleast it's a new vehicle and covered under warranty. better than a used one and NOT be covered. so what if you have to go back and get something fixed. if you didn't do the walk through in the first place, who's fault is that?? just chalk it up to a lesson learned and go from there. be happy that if there is a problem, they have to fix it!
AKLGT1998 Subaru 2.5RS
Vibe_dude
Post by Vibe_dude »
it says about the holes in the back seats,but not the ones in the front......i have the plugs in the back i need the ones in the front..anyone know the part #???
LOVE THAT VIBE 2003 Satilite Silver auto.......188,000kms.2006 Chevrolet Trailblazer White 4.2 Inline 6 291hp auto.........156,000kms.
remusrm
Re: hmmmmm (Sub-Vibe-R)
Post by remusrm »
what sucks is that those 2 plugs they told me they are extras. i need to take it in...
09 MazdaSpeed3 ZOOM-ZOOM
21Rouge
More complete checklist for a brand new Vibe
Post by 21Rouge »
see that the VIN number is correct Is the odometer reading representative of a factory delivered carproper air pressure for the 4 tires (32 psi) the two rubber plugs have been inserted in the underbody (the two holes are located in the vehicle underbody in front of the rear wheels (one hole each side))check that there is an antenna on topfront and rear seat floor mats, cargo cover and a rear cargo mat (if ordered) are present check the condition of the interior clothcheck the plastic interior for sratches etccheck rubber gaskets around the glass are complete and aligned look/ask for evidence of the security etching if applicableget the plastic key code from the dealer and two sets of keysof course be sure that the paint and finish is perfect iespecifically, look for variations/defects in paint and problems with gaps in panelscheck that the owner's manual and warranty book are in the caretc
remusrm
Post by remusrm »
i still can not find this whole. i do have some in the glove compartment...
Vibe_dude
Re: (remusrm)
Post by Vibe_dude »
i took a pic..hard to get under car.lol but i dont know if this will help or not.
