Keyless Entry Range
NewNeptune
Keyless Entry Range
Post by NewNeptune »
I have what seems to be abnormally short keyless entry range. In the cars I've had before this, the range seemed to be quite nice, I could lock and unlock the car from across the house, or about 12-15 parking spots away. Now, my Vibe's remote will only work just barely inside the house or about 3 parking spots away. Does that seem short? Since I'm going to be bringing it in soon for:1st oil changeTire rotationAlignment (it pulls hard left)Tires leak (most are losing about 2 psi every 5 days, one is losing 4!)Thanks!
2006 Pontiac Vibe Base, Automatic, Power PackageSony CDX-GT300Upgraded Horns
northvibe
Post by northvibe »
I think my battery is low in mine, but it seems that it used to be sorta long, 50 feet maybe, :S i know i can do it from my bedroom to my parking spot and its across my yard (college house).
slvrvibes
Re: Keyless Entry Range (NewNeptune)
Post by slvrvibes »
Mine isn't much further, I've been able to lock or unlock about 5-7 car lenghts away. Depends on whether I'm parked next to bigger vehicles or not.
genvibe garage
NewNeptune
Re: Keyless Entry Range (slvrvibes)
Yeah, I've read GM's bulletins about keyless entry range. They say it can be affected by what cars are nearby, nearby buildings, how warm the air is, how bright the sun is... Basically, unless it is almost dead, the dealer doesn't have to do anything with it. Probably not worth mentioning.
BlueCrush
Post by BlueCrush »
Mine is about 50ft.+/-. Your tire leaks may be contributing to your car pulling to the left, so I would get that taken care of first before spending the money for an alignment.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
NewNeptune
Re: Keyless Entry Range (BlueCrush)
Quote, originally posted by BlueCrush »Mine is about 50ft.+/-. Your tire leaks may be contributing to your car pulling to the left, so I would get that taken care of first before spending the money for an alignment.Spend money? I think not. Don't they have a 7500 mile alignment warranty? The low psi contributes a little, but it is still painfully obvious even with the tires freshly aired up.
mcgusto82
Post by mcgusto82 »
why would you want to unlock your car from 12 cars away?? it can be a bad habbit. one day you get a surprize in the back seat.
NewNeptune
Actually, I want to be able to lock it from that far away. I forget on occasion and then remember half-way down the parking aisle.
tnpartsguy
Post by tnpartsguy »
According to GM, the standard key fobs have a 30 foot range, the extended range ones (remote starter equipped cars is 150 feet).
Merzbow
Post by Merzbow »
Mine started out far away but then the range decreased alot so I dunno what's up with that.
http://www.cardomain.com/ride/541918-1999 Infiniti Q45t-2003 base Vibe (Rest in peace my love)-2002 Ducati Monster 620 Dark
Zorren
Post by Zorren »
I am getting after 2months around 75-65ft
Mrs. White: Yes, I did it. I killed Yvette. I hated her so... much... it... it... the... it... the... fee... flames... flames... on the side of my face... heaving... breathless... heaving breaths...
zionzr2
Post by zionzr2 »
try placing the fob to your chin and press the button. With several keyless systems this increases the effective range.
NewNeptune
Re: (tnpartsguy)
Quote, originally posted by tnpartsguy »According to GM, the standard key fobs have a 30 foot range, the extended range ones (remote starter equipped cars is 150 feet).Oooooohhhh...so that is why my Malibu's keyless entry went so far out, but the Vibe doesn't. Thanks!
