Vibration
JamaicanVibe
Vibration
Post by JamaicanVibe »
Recently, my 03 Vibe while sitting at a red light vibrates/shakes. it is not violent, but if you are paying attention you can feel it. What do you guys think is the problem?
2003 Vibe AWD auto w/ moon & Tunes package.
JohnC
Re: Vibration (JamaicanVibe)
Post by JohnC »
Does it do it with/without AC on? Does your engine rpm change at the same time as the vibration? If not check your motor mounts by having someone hold the brake on while shifting into and out of drive/reverse. The motor shouldn't move alot, if it does I would suspect the front mount, but it is always best to replace all three.
northvibe
Post by northvibe »
how many miles are on it? just 41k? sometimes when motor mounts go out it could shake. I also wonder since its a manual if it could be the clutch/tranny? i dont have experience with manual cars though.
JamaicanVibe
Re: Vibration (JohnC)
having the ac on or off does not make a difference. The RPMs does not move either. I will try you suggestion. Thank You
JamaicanVibe
Re: (northvibe)
it has 54000 miles on it and its an automatic
northvibe
Post by northvibe »
did you change your sig? i swear it said GT...unless the coffee made me start to make things up....its been known to happen.If the engine is not in harmonic balance it could vibrate as well. drive around and park the car in your driveway or a lot , pop the hood and get out and check the eninge to see if anything is flopping around more than it should be. If its AWD it could also be the tranny and/or transfer case for the rear drive wheels.
melders
Post by melders »
Quote, originally posted by JamaicanVibe »Recently, my 03 Vibe while sitting at a red light vibrates/shakes. it is not violent, but if you are paying attention you can feel it. What do you guys think is the problem?mine does the same thing...and since i just got it 2 months ago, i dont know if it is supposed to do that, or if something is wrong...i got it with 46,000 on it, and now it has 51,000...i thought about the motor mounts, but if someone else's is doing it, maybe its supposed to do it?any thoughts with this, would be extremely helpful, not only to me, but probably to jamaicanvibe as well
2009 Pontiac Vibe GT - Jet Black Metallic
Tubaryan12
Re: Vibration (melders)
Post by Tubaryan12 »
What's your rpm's at idle? If it's too low that will make the car vibrate.
ex Vibe: 2005 Abyss 2 tone base, auto, power package (33.24 mpg combined)2008 Kia Rondo EX V6 7 passenger Volcanic Red w/ tan cloth interior (26.7 mpg combined) Finally got 30 mpg combined on the Rondo V-6 (10.24.09) Smith Driving
melders
Re: Vibration (Tubaryan12)
Post by melders »
i want to say less than 1000. i dont remeber exactly...ill take a look when i head out tonight, and let yall know...is that bad that its low? i know it is low its half way between the last number on the rpm thingy and the end
Digger
Post by Digger »
this came up some time back and I just finished reading an artical in PM that addressed this issue. It said to lossen up the motor mounts then retighten them. should fix the issue. I would use a torque rench when doing it though.
northvibe
Post by northvibe »
+1 to digger's fix.I've heard of doing this too worth a shot.
