Matrix Console Vs. Vibe Console
Peter
Post by Peter »
For the 05/06, does anyone know if there is a difference in the center console. I think the matrix still has the 12V in the console, but as far as the dimensions, are they the same?I seem to recall someone telling me that the matrix one is a little taller?Thanx
2006 Frosty Vibe1998 Civc Si
GMJAP
Re: Matrix Console Vs. Vibe Console (Peter)
Post by GMJAP »
They are the same. The 05/06 Matrix still has the higher lid with storage tray in it - this was also in 03/04 Vibes & Matrixes. However, GM decided to change to a lower, simpler lid without the storage tray starting in 05 Vibes. The lids are interchangeable, however,
Peter
Re: Matrix Console Vs. Vibe Console (GMJAP)
Post by Peter »
sweetthanx for the info So all I need to buy is the tray and using my existing lid, I can bolt everything on ?
GMJAP
Post by GMJAP »
Quote, originally posted by Peter »sweetthanx for the info So all I need to buy is the tray and using my existing lid, I can bolt everything on ?Not quite. You'll need to get a new tray & lid combo, and replace your existing lid. See the following thread (about 1/2 way down the first page):http://forums.genvibe.com/zerothread?id=12602PS- It's much cheaper to get the lid from Toyota than GM
DHelm72
Post by DHelm72 »
I have an 05 and the cheapest double lid I could find was $70. I ended up buying an entire console from a wrecked 03 at a salvage yard for $29. I Just swapped the lids and installed the cigarette lighter plug into my 05. I got the lid and a bonus 12 volt plug all for $29. The taller lid makes for a good arm rest and the extra storage is nice.Good luck with your search! David
