well ive been looking around the site for a while, but havent really found an exact how to, but i'm wondering how to make the 03-04 typhoon intake work without CEL for the 05, reason is i just ordered one and it should be coming in the mail in a week or 2. any close of pics of what is supposed to be capped off would be GREAT. thanks for the help
Markt2717 is your man. Here are some pics of my K&N in my 06. You'll need a small intake ($10) for the tube coming out of the engine where mine was plugged.http://i114.photobucket.com/al...1.jpgh ... .3.jpgHope this helps!
“I live my life free of compromise, and step into the shadows without complaint or regret.â€
Viva la Pontiac! 2009 Jet Black GT
so the intake that i bought has none of the hardware include (ie. T and C brackets) i was wondering if anyone knows any place that i could purchase these. do i need the name brand stuff or does like a hardware store or someplace like checkers have what i need???
Quote, originally posted by 1zzfe_808 »that silver thing is one of those crank case filters??? from the pics it looks like a plug.It is was a plug, but I replaced it with a small filter/intake thing...
THis is what it should look like anything else is kinda wierd. And THIS is what it should look like all together. That crank case is very sensitive. you HAVE to have a filter on there you CANNOT afford to not have one on there.
no header, K&N Typhoon SRCustom Red Painted Engine W/ Black Lettering, Monsoon Sound Sirius Satalite Radio, Xm Satalite RadioRed Led Underdash Glow/ Spotlight on Vibe Symbole, Red Grill LightsRed LED Wireless Remote Controled Underglowhttp://www.cardomain.com/ride/2402619
Quote, originally posted by 1zzfe_808 »so the intake that i bought has none of the hardware include (ie. T and C brackets) i was wondering if anyone knows any place that i could purchase these. do i need the name brand stuff or does like a hardware store or someplace like checkers have what i need???The hardware is supposed to be included with the intake kit. If it were me I'd get on the horn with K&N.
'04 Shadow Monotone Base AT power pkg., + FIAMM low note horn, GM exhaust tip, GM splash guards x 4
Quote, originally posted by kcorona »The hardware is supposed to be included with the intake kit. If it were me I'd get on the horn with K&N.The problem is he got a intake made for a 03/04 that is NON drive by wire and he has a 2005 which is DBW and their throttle bodies are different thus meaning the intake is a little different. To make it work it needs to have some custom work done.
well talk to Toasted7... he made a 03-04 work on an 05-06. you pretty much have to make your own inlet to the intake and connect that hose from the engine there.
Quote, originally posted by Mrizzle05 »well talk to Toasted7... he made a 03-04 work on an 05-06. you pretty much have to make your own inlet to the intake and connect that hose from the engine there.Nope, Toasted7 had a Cosmo Cold Air Intake not a K&N typhoon, stick with Mark's setup. And good luck, your going to need it. http://www.cardomain.com/ride/501501
Intake on vibe is awesome. I have a auto vibe with a TRD cold air intake (2004 auto vibe) and its freaking sweet. It sounds louder up front, like a growl and when i drive nice my gas mileage goes up it will not make your exhaust any louder just your air sucking up front.
Thanks, I was thinking of going with the k&n worm air intake. The car is still under warranty so I don't want to go to crazy. I just got into the vibe. I use to drive a 92 Nissan Se-r.
RFP1 17x8 , AFE Cold Air Intake, Helix Power Tower Plus, Eibach Sportline Springs with Tokico Blues, Progress sway bar, Alutec OEM Sized Lightened Crank Pulley full custom Magnaflow 2.5 header back exhaust and B&M tranny cooler E/S inserts Unichip.
Quote, originally posted by vibe Freak »Is it worth doing the intake on a auto Vide. Also how loud will it make the stock exhaust ? Thanks Dominic With my K&N intake, The Vibe is loud enough to turn the head of any ricer. And probably give you a boost of 7-10hp.
Has anyone tested the impact on MPG? I would think that it should increase by a notch or two, provided that once it's installed the driver doesn't hammer down everywhere he goes.
Quote, originally posted by skylinedrifter »... provided that once it's installed the driver doesn't hammer down everywhere he goes. Good luck with that.
K&N has it dyno with 167 at the wheels. that is an extra 12 hp. I love mine. it is almost as loud as the exhaust. I have a pic of the vacuum lines if you need it.
