Factory radio wiring problem?
03vibeowner
Post by 03vibeowner »
hi I actually currently have 3 vibes..... and tried 2 of the radios in one of them lol 2 of them we bought used but in the one we actually bought from the dealership. I believe its the wiring...... on both radios you can get the acurate time but it will not come on.... so I think that it is still getting some power to keep the time BUT you have to push the like rce or something button and it will tell the time but you push the main button (that is used for volume) and nothing happens..... has this happened to ANYONE else? I am fearful that something has happened to the factory wiring NOTHING modified has messed up and that the dealership will do NOTHING for us.... if anyone has any ideas please contact me :D thanks alot
GMJAP
Re: Factory radio wiring problem? (03vibeowner)
Post by GMJAP »
Quote, originally posted by 03vibeowner »hi I actually currently have 3 vibes..... and tried 2 of the radios in one of them lol 2 of them we bought used but in the one we actually bought from the dealership. I believe its the wiring...... on both radios you can get the acurate time but it will not come on.... so I think that it is still getting some power to keep the time BUT you have to push the like rce or something button and it will tell the time but you push the main button (that is used for volume) and nothing happens..... has this happened to ANYONE else? I am fearful that something has happened to the factory wiring NOTHING modified has messed up and that the dealership will do NOTHING for us.... if anyone has any ideas please contact me :D thanks alotSounds like it getting battery power, but not ignition power. Try checking the fuse block.
03vibeowner
for what? what fuse do I need to check? is there one for the stereo I don't think, prob is but I know the ignition wire is working because the windows roll down.... the A/C works and the gaudges work so I really don't know but thanks for the idea I will tomorrow when there is light outside
mcgusto82
Re: (03vibeowner)
Post by mcgusto82 »
look under the driver's side steering columm. there is a black rectangular plastic box. that is the fuse block. look for the one that says "cig" that is the radio fuse. check that.p.s. the black box is underneath the pull out drawer.
03vibeowner
lol now i'm confused... are you talking about the one the box under the dash or the one behind the little pull out drawer
Jahntassa
Post by Jahntassa »
They're the same thing. The fusebox under the driver side of the dash has relays on the top of it, which can be viewed by looking behind the pull-out drawer.To get to the fuses, though, you have to go from underneath.
03vibeowner
yea I just wasn't sure which he was talking about I know exactly where it is..... thanks alot I will say if it works or not
