springtime in alaska and its -40* below..
red
Post by red »
with the 35 mph winds and the -15* to -20* below zero base temps...its mighty cold up here....my awd is doin' fine, can feel the wind push it a little, but not bad at all Nytmare down in anchorage has it worse...they have up to 60mph wind gusts and it is hovering around 0* above (probably -50* below zero wind chill)...aahhh alaska living..nothing else like it
latina_qt
Re: springtime in alaska and its -40* below.. (red)
Post by latina_qt »
I'm from California so I definitely don't have to worry about that but thanks for the info! I bet it's pretty up there.
Latina QT
pmh013
Post by pmh013 »
quote:...its mighty cold up here....So, should I rub it in that it is ABOVE freezing here? Snow is melting fast. With the weather like this, spring will be here in no time."If there's a foot of snow, it just means I don't have to mow my lawn!" -- Audio Wearhouse commercial
2003 Satellite AWD Two Tone, traded off at 180,126 kmNow the (fourth) catalytic converter is someone else's problem Now driving a 2007 Dodge Grand Caravan
canadavibegt
Re: springtime in alaska and its -40* below.. (pmh013)
Post by canadavibegt »
Well I'm with the Californian....... It snowed twice this year and lasted about a day each....... been below freezing a couple of days..... The trees and flowers are already in bloom......... I can simpathyze with all in the cold lived in northern Sask and Alta for about 15 years
Canada Rocks View pics of my car here. http://www.cardomain.com/member_pages/v ... _id=345207
