Mass AIR SENSOR
Digger
Mass AIR SENSOR
Post by Digger »
There is an article in this months popular mechanics that tells how to clean your mass air sensor on page 105 of the august 2006 issue.
BlueCrush
Re: Mass AIR SENSOR (Digger)
Post by BlueCrush »
Ok, Thanks. What does it say? Can you scan and post it?I would recommend brake cleaner or MAF sensor cleaner. (both are sprays)
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
northvibe
Post by northvibe »
I could bring my MAF sensor cleaner to the meet......
BlueCrush
Re: (northvibe)
Post by BlueCrush »
Good Idea! Bring it!
My Fleet:
Digger
Post by Digger »
It basically said to spray it off with the MAS cleaner. ( You can use the other stuff also but it cautions you about melting the plastic parts) It also tell about the natural cycle they have to clean themselves. They have a regular self cleaning cycle where the wire element in them heats up to burn off the crud. They say this happens after you turn off the car every so often.
northvibe
Post by northvibe »
my MAF sensor cleaner didnt melt my plastic thankfully but it seemed more like rubbing alcohol..but a little stronger.
Digger
Re: (northvibe)
Post by Digger »
The article did recommend the MAS cleaner over other solvents due to the MAS cleaner would not eat the plastic
