So what does all this mean?Are GM Canada customers getting the thick end of the stick again?Why does the heading say Hummer H2?Can we pop in and get a new beefier battery upon request?What kind of bug is that on my leg?
quote:gm's aware that batteries are failing early. its simply a technical service buliten. your battery has to fail, and then gm will replace it right away.No, GM is just changing warranty handling policy. It is not a technical bulletin. Your SECOND battery failure is now eligable to be handled by a GM dealer instead of an AC-Delco authorized serive outlet.
It gives me great comfort knowing that if my battery fails and strands me, that I might THEN be able to get it replaced under warranty. NOT! When it starts getting weak(er), I'll replace it at the drop of a hat.
Lorin2003 Pontiac Vibe GT, Neptune-mono, moons & tunes, power package, side impact airbags, rear seat covers, bumper protector, cargo mat.Mods installed: TRD exhaust, TRD stb, Mods removed: TRD CAI - annoyed by CEL
All this means is that if you buy a replacement AC-Delco battery from either a GM Dealer or an ACDelco battery distributor and it fails and causes damage to other parts of the vehicle the dealer won't make you pay for the repairs to the damaged parts and then get reimbursed. They will handle the process and get reimbursed by AC-Delco. It's just less hastle is all.
