front right shock leaks
Thewhite
Post by Thewhite »
and not just a little. a lot. there's grease all over it, and some on the ground where I pack it, and my ride has changed a lot, specially on crappy roads. I was thinking to get rid of my spring at the end of this summer, so it will be now. I have already 105 000 km on my car, 40 000 with the springs. I'm about to buy a brand new OEM shock to replace it, but I just thought that I'd save a lot of money if I take a used one. I don't know how long I'll be able to keep the other three, so I might not buy a new one... I don't know. what you guys think?
'03 Vibe StandardFast Wheel Talon 17x7 Toyo Proxes T1-S 225/45Magnaflow Cat backDevelop's Strut Tower Brace
Mrizzle05
Re: front right shock leaks (Thewhite)
Post by Mrizzle05 »
look into aftermarket one... not like performance but they make just everyday driver ones that are probably cheaper than the OEM ones. and may even be better.But thats one idea and one opinion! Good luck
Psychobroker
Re: front right shock leaks (Mrizzle05)
Post by Psychobroker »
Quote, originally posted by Mrizzle05 »look into aftermarket one... not like performance but they make just everyday driver ones that are probably cheaper than the OEM ones. and may even be better.But thats one idea and one opinion! Good luckSadly, unless you go with Koni Yellows (search under Corolla), there are no aftermarket shocks for us yet. KYB's (GR2?) are OEM...from what I've read here and at http://www.matrixowners.com.
