Ok so i just put in some headliht ( acctually in the turn signal) strobes (blue) from OPTX & i also instaled 3 -- 6inch interior neons.. one under each front seat, and one in the trunk. it took me about 40 mins. i still had to strip some wire... my setup is not so neat, but i will try t get to it tomo. the trunk neon's wire is hidden, except for its transformer( 4th image), ill get around hiding it the controllers for both things are not so neat (3rd image )SORRY 1ST PIC IS REDISH , DUE TO ME HAVING TO COVER FLASH... http://i36.photobucket.com/alb...1.jpgh ... lb...4.jpg
VERY illegal so watch out, looks good though but for it to fill your entire housing you need 2 strobe kits in each headlight housing because of the shape and size of the vibes headlights.
04 Fusion Orange Base Vibe auto Now no longer with us thanks to ignorant drivers...
nope.. acctly, i just took out the turns, stuch it in there, and put them on again.... pretty easyyesss... very illegal , specially in georgiahey BlackVibe_05.. where in ATL are you.. im in ATL now.. we moved
