try this site ptuning.com. this is where i got mine injen cai from for $203 shipped!!- also if you use this link you will get 5% off of anything there since were on genvibe. ( i didnt relize that till after i got my intake. )heres the discount link discount
actually there is a injen intake out there for the 062s and some 05s. because some 05s are the drive by wire and the others are controlled electronicaly. so some of the 03-04 intakes should fit the 05 vibes. yhe way to tell if you have the wire look at the throttle body and look for this (the green circle.)
if you have a 03-some 05, i just got the TRD one and like it alot. injen is a good one too.If you have the DBW then you'll need a cosmo or soon to be released injen....
Nascar, that is the drive by cable throttle, not the DBW.Drive by cable throttle or CCT = Cable Controlled Throttle:Drive by wire throttle or ECT = Electronically Controlled Throttle:
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
