Has anyone spliced into the"fake"red radio alarml light to add another fake alarm light?
lexicon
Post by lexicon »
It occured to me, that if I dont have an alarm, why couldnt the red radio flashing light on the radio be spliced and tapped to add another LED flashing light.This would be a better deterrent !!!I know that LEDs need some kind of resistor ( I am not electronically inclined)Ive seen newer Toyotas that have a blue LED under the driver side dash .How would this be done?I will also post on the Matrixowners website
2005 VibeAutomaticStockNon AWD125 hp model
northvibe
Post by northvibe »
or get a led that flashes or phases and put it on a battery or tap into the cars power or battery.
GMJAP
Re: Has anyone spliced into the"fake"red radio alarml light to add another ... (lexicon)
Post by GMJAP »
Quote, originally posted by lexicon »It occured to me, that if I dont have an alarm, why couldnt the red radio flashing light on the radio be spliced and tapped to add another LED flashing light.This would be a better deterrent !!!I know that LEDs need some kind of resistor ( I am not electronically inclined)Ive seen newer Toyotas that have a blue LED under the driver side dash .How would this be done?I will also post on the Matrixowners websiteThere's no need to tap into the Radio LED. You can buy LEDs that blink by themselves. Ex:http://www.radioshack.com/prod...earchh ... ..earchAll you'll need is a resistor to hook it to +12V, and a switch if you want to turn it on/off. The resistor value depends on the LED used.If you have a specific color in mind, let me know I'll see if I can find one or let me know what one you get & I can give you resistor value.
lexicon
The radio light only comes on when the ignition is off
Post by lexicon »
I want this to come on automatically when the key is out.Otherwise, I would have to manually turn it on
P-Fernandez
Post by P-Fernandez »
hmm... get a bmw mirror alarm cover ( red) put a led in it, wire it.theyll thik you have a bmw alarm .... hehe
Jahntassa
Re: The radio light only comes on when the ignition is off (lexicon)
Post by Jahntassa »
Quote, originally posted by lexicon »I want this to come on automatically when the key is out.Otherwise, I would have to manually turn it onThere are many blinking LEDs you can get commercially sold by companies like Varad and Streetglow that will turn on when you turn off the car. Local car parts stores should have them.Varad LED at Pepboys
GMJAP
Re: The radio light only comes on when the ignition is off (Jahntassa)
Post by GMJAP »
Quote, originally posted by Jahntassa »There are many blinking LEDs you can get commercially sold by companies like Varad and Streetglow that will turn on when you turn off the car. Local car parts stores should have them.Varad LED at PepboysExcellent find!(I was going to suggest using a relay to turn it on when the car is off, but you can't beat that.)
jake75
Re: The radio light only comes on when the ignition is off (GMJAP)
Post by jake75 »
Do you mean that the red blinking light in my Vibe is a fake?
GMJAP
Re: The radio light only comes on when the ignition is off (jake75)
Post by GMJAP »
Quote, originally posted by jake75 »Do you mean that the red blinking light in my Vibe is a fake?Well, it's a real blinking light But if you were to assume it meant anything, then it'd be faking you.
Mrizzle05
Post by Mrizzle05 »
^^*scratches head*HUH?
Baltovibe
Post by Baltovibe »
I did the exact same thing. I bought an LED flasher at a local electronics store, installed the LED by drilling a hole in one of the empty switch panels and pushing the LED through it, and running the 2 wires to the dome light switch electrical connector. The wires just inserted into the connector harness that connects to the dome light switch ... no soldering needed. Easy 15 minute job, and looks like a real alarm system!
NascarXprt
Re: The radio light only comes on when the ignition is off (Mrizzle05)
Post by NascarXprt »
on your stock radio there is a little red light that flashes like an alarm light. that is a fake alarm light. it should be located under you volume knob.
My '04 Garage - My '06 Garage - My '09 GT Garage
November 2006 MOTM / February 2007 VOTM / April 2010 VOTM / June 2011 VOTM
Mrizzle05
Re: The radio light only comes on when the ignition is off (NascarXprt)
Post by Mrizzle05 »
No i meant by how GMJAP said that quote... Quote, originally posted by GMJAP »Well, it's a real blinking light But if you were to assume it meant anything, then it'd be faking you.
NascarXprt
oh ok now i know not to assume anything now. but after you go back and read his quote its pretty strait out. basically that light is faking that it is the alarm light.
lexicon
SO, how does this LED turn on and off automatically when you remove the key?
Post by lexicon »
Glad to hear you got this to work, but ,How does this LED that you wired turn on ? And does it automatically turn off?
josholiver1
Post by josholiver1 »
So if you disconnect power to the battery and hook it up again the player wont say "locked"?
Jahntassa
Re: (josholiver1)
Post by Jahntassa »
Quote, originally posted by josholiver1 »So if you disconnect power to the battery and hook it up again the player wont say "locked"?It shouldn't. From everything i've seen there is no lock on the Vibe radio.
