biq question.. plz help me
P-Fernandez
Post by P-Fernandez »
so i got the reflector overlys.. and i got some q'sINSTALLED!!!! ook for my tread " Reflector overlays & arrowhead oeray installed"- Do you have to take the headlight assembly off?- If you did it, did you use water and soap.. like it says on install sheet?
northvibe
Post by northvibe »
i just cleaned the spots with a wet wipe aka rubbing alcohol in a wipe . soap and water will do too, wait till it dries. Where did you order them from? i think vinyl like that you spary a little soapy water on the back of the vinyl and then lay on the head light and smooth out with like a credit card. you should not have to take off the headlight.
scherry2
Re: biq question.. plz help me (P-Fernandez)
Post by scherry2 »
no removal needed. use soap and water and I used a blowdryer (not close), your working with a compound curve so take your time. they go on easy just follow the instructions.
P-Fernandez
ok wel thanks..i did it about 1 hour ago. i cleaned it, sprayed soap & water, put it on there stretch it out little by little, and the used a blowdryer. 1st one--- not perfect2nd one--- good
NascarXprt
Re: (P-Fernandez)
Post by NascarXprt »
try and get some pics of final product.
My '04 Garage - My '06 Garage - My '09 GT Garage
November 2006 MOTM / February 2007 VOTM / April 2010 VOTM / June 2011 VOTM
P-Fernandez
i jst posted a tread about it and pics.. Relector overlays & arrowhead overlay "instaled:
NascarXprt
Re: (P-Fernandez)
yea i kind of saw that after i posted this looks great by the way
