Tach Help
MarathonVibe
Tach Help
Post by MarathonVibe »
How do you set up a Tach ?
MaRaThOn ViBe
Jahntassa
Post by Jahntassa »
I guess you mean a second tachometer? Did you buy one yet, and if so, did you look at the instructions?
MarathonVibe
well i got it used from a friend and the only thing i really need help with is the green wire. I know on my old car it went to the coil.
MaRaThOn ViBe
djb383
Re: (MarathonVibe)
Post by djb383 »
The green wire goes to the negative side of the coil, usually.
'05 Lava Tutone base, Pwr Grp, Moon & Tunes, 16" alloys, Auto.....Yep, it's gotta HEMI
Jahntassa
Post by Jahntassa »
According to the sheet I used to put in my remote start, here's the colors:Coils:- Red/Blue- Yellow/Green- Gray- WhiteFor the remote start, I used the fuel injector wire, which is the wire at any fuel injector that is NOT black/white
MarathonVibe
Thanks i will give that a try
MaRaThOn ViBe
