When a "hot start" issue might not be a "hot start" issue.
Cougar Vibe
Post by Cougar Vibe »
Well, today was the first time I've experience the 1ZZFE hot start problem. However, after reading through several threads about it, I'm not sure what happened was the same thing.Specifics: 2005 Vibe w/5k miles. Drove the car for about 25 minutes at 40mph, then parked the car for about five hours. Went to start it and it didn't want to catch for about three seconds; turned the ignition to off, tried again and she started up no problem. Anything else I've read seems to indicate the hot start issue took place within an hour or so of being parked. Has anyone had the "hot start" issue with such long intervals?Thanks,Cougar Vibe
djb383
Re: When a "hot start" issue might not be a "hot start" issue. (Cougar Vibe)
Post by djb383 »
Yes, both of my '05s have done it once in the past 6 months. Wouldn't start during several seconds of cranking, turn key off and try again, then fires right up. What's up with that.
Toasted7
Post by Toasted7 »
The time frame on my 05 has been anywhere from 20 mins to a few hours... exact same problem.
VMFIC of Cincinnati Scikotics Cincinnati Scikotics sponsored by: KerryScion.com My other ride is your mom
orbix
Post by orbix »
Same thing here- I can't find any correlation between the starting issue and how recently the Vibe's been driven.
Toasted7
Re: (silverawd26)
Post by Toasted7 »
I wish they would figure out what the problem is and actually get it fixed for everyone out there that is having this problem... it's really annoying.
ragingfish
Post by ragingfish »
FWIW, I experience a similar random glitch in my G6. Difference is, it's not a no-start issue, but rather a "the engine started but the starter keeps cranking" issue.
2009 PONTIAC G8
Atomb
Re: (silverawd26)
Post by Atomb »
Quote, originally posted by silverawd26 »Not sure if it is a hot start ot cold start, but Toyota has had similar problems on some of their vehicles and there is a TSB out for certain models tro update the a part in the fuel tank. I guess the fuel is falling back into the tank. Hands are tied until GM comes out with a similar TSB.then would rotating the key to the power on position for a few seconds before rotating further to engage the starter help the situation? That would get the fuel pump going right?i don't have this problem on my 04 but i feel for you all!
Re: (silverawd26)
Quote, originally posted by silverawd26 »That is prob because your GM has a Direct Ignition (?) or whatever its called, just tap it and it should start, I think your still used to having the Vibe. Back off a bit on the key, just tap it and it should start right up. Recent GM products do seem to have a timer of some sort set up for the starter. You really don't have to to hold the key at the start position anymore. It will keep cranking after you let off of the key, so even if you turn it for just half a second or so to start, you can let off it and it will continue to crank.
Image Image
ragingfish
Re: (ColonelPanic)
Quote, originally posted by ColonelPanic »Recent GM products do seem to have a timer of some sort set up for the starter. You really don't have to to hold the key at the start position anymore. It will keep cranking after you let off of the key, so even if you turn it for just half a second or so to start, you can let off it and it will continue to crank. Correct.The starting sequence is all computer controlled. You just "touch" the key to the start position and the computer auto-starts the engine. There is a glitch in many 05 and 06 G6 models (and possibly Malibus as well) that causes the car to occasionally over crank and keep the starter going even after the engine has fired.On the same note, however, once the engine is running, you can't accidentally blow the starter up by turning the key to start. The computer locks out the starter once the engine is running, so turning the key to start while the engine is already running results in nothing happening.It rocks.
2009 PONTIAC G8
vibrtor
Post by vibrtor »
There is a TSB on this problem. TSB 05-06-04-074 - hot soak issue. Resolution: new PCM
csharrigan
Re: When a "hot start" issue might not be a "hot start" issue. (vibrtor)
Post by csharrigan »
Unfortunately the said "fix" doesn't solve monsts problems.
scherry2
Post by scherry2 »
Quote, originally posted by Cougar Vibe »Drove the car for about 25 minutes at 40mph, then parked the car for about five hours. Went to start it and it didn't want to catch for about three seconds; turned the ignition to off, tried again and she started up no problem. my 03 has done that since I bought it every summer when it gets hot GM's reply:cannot duplicate.....
