installing GPS tomorrow, reverse indicator location?
jeffgtx
Post by jeffgtx »
installing a kenwood GPS tomorrow and need a reverse indictor so the gps knows when i am going backwards, should i decide to go backwards whilst being navigated.anybody know an easy place to get that in the inside or do i need to go to the reverse lights in teh back?
JeffGTX's Shades Of Gray Pontiac Armada:Cool: 2008 Solstice GXP ConvertibleSly: 2009 Solstice GXP CoupeMaverick: 2009 G8 GXP
Jahntassa
Post by Jahntassa »
I know where it is if you had the Nav system Not sure where you can get it other than the reverse lights, but then I don't have a book on the car.
mcgusto82
Re: (Jahntassa)
Post by mcgusto82 »
i agree with jahntassa. the reverse light is a good place to start. there should be a 2 wires that come out of the tranny near the shifter cables. (i think) you could trace them into the fire wall.
jeffgtx
Re: (mcgusto82)
Post by jeffgtx »
the answer is right behind the glove compartment. to the right of the ECU is a white connector with a red/blk wire coming out (pin 4 i believe) which goes to 11V when reverse is engaged.
