Where Can I find 12V Power and Ignition sense
wpj
Post by wpj »
hey all,I have partially installed a Motorola Bluetooth Kit in my '05 vibe but I now need to find 12v always on power and ignition sense or 12v while enion is running power, I need about 4 A on the always on and 3 amp on the ignition. those are max and the always on draws hardly anything until igition is on.thanks in advanceWill
Jahntassa
Post by Jahntassa »
On the radio harness:Blue/Yellow - 12v Constant (pin B1)Gry - 12v Switched (pin B2)They'll feed your kit fine.
Re: Where Can I find 12V Power and Ignition sense (wpj)
Jahntassa slipped that in right before me, that'll work just fine for ya.For what it's worth, I used an Add-A-Circuit to connect to the CIG fuse for some LED's that I no longer have installed and the electrochromic rearview mirror. That gives me switched power with the ignition. Along the way, I found the P/POINT fuse is hot at all times, so that could be used to tap into for 12V constant. But I don't know about how safe it would be with the added amperage on these circuits...
Image Image
Jahntassa
Post by Jahntassa »
Nah, if it's just a bluetooth handsfreekit, he should be fine. I ran my normal handsfree kit off those circuits with the NAV system with no problem.
wpj
Post by wpj »
thanks Guys, I was hopping to tap into the radio harnis but I only have about 1/2 inch to play with with out ripping it apart, they didn't leave much room, I I can't even get the radio out unless I get my hand back there and remove the connector, I assume that this is normal.I will see what I can do this week/weekendWill
Jahntassa
Post by Jahntassa »
Eh sorta. You can unplug the radio without fear. There's no 'lock' on it or anything.
wpj
Re: (Jahntassa)
Post by wpj »
ya I ahve had the radio out once, but with out knowing the right fuzes to take out to stop that red led from flashing it still scares me a bit.
Jahntassa
Post by Jahntassa »
The red light is literally a decoy. You don't need to take out any fuses, you can just pull the harness from the radio without any need to worry.
Vibr8tr
Re: (Jahntassa)
Post by Vibr8tr »
I agree with the radio wires, I put some LED's on my dash, just under the radio cover, and wired them into the Green wire on the harness. That one is linked into the dash ligts, so the LED's come on then the headlights come on, and the Voltage is controlled. As for a constant and switched 12V the harness is your best bet, and you are pulling so few Amps,that you should have NOTHING to worry about.
MSN: jjbova@hotmail.com - Yahoo: jjbova - Myspace: http://www.myspace.com/jjbovaSee My Vibe at Cardomain.com
