http://tinyurl.com/56t9uusing the track pad on my laptop i couldn't get higher than just over 11 seconds...i think i could do much better with a mouse.
I thought one of those scary faces would pop up. hahah so i was at work and had all my sound down and had this semi scared look on my face until i hit 20 something seconds and realized this might be real
I got 21.225 after 5 tries!!! its trippy... i was started to work a sweat! Nice find!
I normally can't get past about 18 seconds.You bunch are WAAAY better at this, or maybe just more dedicated.Somehow I got an error that reads -54.015 seconds.If I could figure out how to cut and paste it, I would.
05 Base Vibe, Abyss (also known as Black to un-Vibers)Auto, Power Pkg, 16" alu, 20% tint all around, Black powder coated roof rails (the anodizing didn't last in the sun)Member of S.A.V.E. (Secret Association of Vibe Enthusisasts)
Quote, originally posted by Atomic »I normally can't get past about 18 seconds.You bunch are WAAAY better at this, or maybe just more dedicated.Somehow I got an error that reads -54.015 seconds.If I could figure out how to cut and paste it, I would.First, you only have to move the red box a couple of times in the first 18 seconds: move straight down until blue boxes cross, then move to upper left corner for about 10 seconds. Then move around to the bottom left corner (a little zig zag there) and wait until an opening appears above left center. After that, stick near the bottom half of the area. And BREATHE! To cut n paste the box, press [Alt] + [Prt Sc] (Print screen) on your keyboard after it appears. That will save the box in the clipboard. You can then paste that in MS Paint and save it as a jpg file.Quote, originally posted by Atomb »wow!!i love the little comments under your time! Yeah; I added those in MS Paint after I did the screen grab. Seemed appropriate.
