SR Cold Air Question (after installation)
Danski
Post by Danski »
Hello … I’m having a problem with my SR K&N intake. I own a 03 Vibe GT, after installation I have left the VSV sensor without any air connection. Everything works great, but after like 30 minutes of driving the PWM vacuum switch it starts make some (klik,klik,klik) like old “Clock” counting seconds but faster. Have you had similar situation?? If yes what I did wrong and how can I fix this… Thank you Daniel
Psychobroker
Re: SR Cold Air Qestion (Danski)
Post by Psychobroker »
I believe that's normal.
BlueCrush
Post by BlueCrush »
VSV ticking is normal. just make sure it is in a vertical position and not tilted on it's side at all otherwise you wil get a CEL. I had to zip tie mine to keep it vertical.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
Danski
Re: SR Cold Air Qestion (BlueCrush)
Post by Danski »
Thanks for the info, i hope that i did no mistake with my instalation..Thanks
