Noise in the engine.
dallarosaj
Post by dallarosaj »
I replaced my stock header for a DC Sport one and now I have a sweeking noise where the header bolts into the cat, has anyone ran into this problem if so how did you stop the noise. I do not know if its the bolts or the gasket. Please let me know.
BlueCrush
Re: Noise in the engine. (dallarosaj)
Post by BlueCrush »
Have you tried re-tightening the bolts?
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
Psychobroker
Re: Noise in the engine. (BlueCrush)
Post by Psychobroker »
Quote, originally posted by BlueCrush »Have you tried re-tightening the bolts?That would be a good idea. Also, make sure they're torqued to spec.
Dezz1
Post by Dezz1 »
Did the headers come with a gasket for the CC, and if so is it positioned correctly?
Even Free isn't Free, Someone has to pay for it. Check Out My Vibehttp://www.cardomain.com/memberpage/571609
Lancer
Post by Lancer »
It could also be that the spring bolts haven't settled yet. But yeah, tighten them a little more and give it a good shake to help them settle in place.
dallarosaj
Re: Noise in the engine. (Lancer)
Everthing is tight and lined up how it should be the sweeking just wont go away.
dallarosaj
Everthing is tight and lined up how it should be the sweeking just wont go away. What do you mean by settle?
northvibe
Post by northvibe »
did you grease the bolts? and lube the gasket?
dallarosaj
Re: (northvibe)
Lub the gasket? no I did not what type of lub should I use for it without it burning off the gasket? as for the bolts/springs should it need lub?
northvibe
Post by northvibe »
hmmm now to think of it..it might have to be special stuff because that header is going to get HOT. check a auto store and see what they say.
