easily fogging up?
microELVIS
easily fogging up?
Post by microELVIS »
Is anyones vibe bad for fogging up in wet weather ie rain or snow? Mine seems to be pretty bad for it, after a car wash it seems fine if its relatively dry. But last night it was washed quickly and not dried and seemed to fog up. The defogging works ok, it just seems to fog easily when its wet out or the car isnt dried. Can anyone atest to this as well?
'03 neptune vibe (first new car)86 GN, 12.96 @ 104 17psi
NovaResource
Re: easily fogging up? (microELVIS)
Post by NovaResource »
quote:Is anyones vibe bad for fogging up in wet weather ie rain or snow?What do you think causes fog? Humidity. When it's wet out you have high humidity and therefor fogging. What did you expect?
Flip-Side
Re: easily fogging up? (NovaResource)
Post by Flip-Side »
quote:What do you think causes fog? Humidity. Lol. Yeah the fogging seems worse with all that extra space in the car, but it really isn't. If It really bothers you, you can buy "Never Fog" or a like product at an auto store. You coat the windows and wipe it off to prevent fogging.
NovaResource
Re: easily fogging up? (Flip-Side)
Yeah, Rain-X Anti-Fog works well. I haven't used it yet on the Vibe but it has worked well in my other cars.
Frosty
Post by Frosty »
Turn up the heat a little bit as well. I use my vents and recirculate for fast heating, but it fogs the windows a bit. So I switch back to defrost and the car defogs instantly, cold or warm, with the fan at 3 or 4, heat on high.Good luck.
Frosty 5 speed Vibe Power & Safety Packages. Naturally Aspirated my gallery
microELVIS
Re: easily fogging up? (Frosty)
Thanks guys, ill see what I can fool with.
snowbeast
Post by snowbeast »
i was driving in the rain a few days ago, and couldn't get the back windows defogged. i had the defrost on high (hot air) with recirculated air. that worked well for clearing the windshield, and after some time, cleared the front side windows as well. however, even after 20 minutes, i still couldn't get the side back windows clear. any ideas?
susanfrosty two-toned/auto/power/cargo box, nets, mat/seatback storage & first-aid/bumper protector/steel exhaust tip/pinstripe
Sputnik
Re: easily fogging up? (snowbeast)
Post by Sputnik »
I thought that recirculate causes some fogging.
GenVibe Global Moderator
Current: 2012 Nissan Juke SL - Sapphire Blue Onyx (July '12 - present)
Current: 2012 Nissan Leaf SL 100% Electric - Blue Ocean (Dec '11 - present)
Past: 2003 Pontiac Vibe - Satellite Silver (Aug '02 - Dec '07)
Vibe
Re: easily fogging up? (Sputnik)
Post by Vibe »
Yes--You are correct. If my recirculate button is ON I do expereince fogging ,but if it is OFF (Green Lite Off) then fogging has never been a problem. James
snowbeast
Re: easily fogging up? (silverawd26)
Post by snowbeast »
in that specific situation (wet and cold outside), it seemed like the windows defogged faster with the recirculate on. i actually only tried it after having read on some thread here that recirculate ON would defog more effectively. the fogging and the air moisture scenario do make sense. what are other ways to deal with this that have been effective?any idea how the anti-fog works? (i could go get it at the store and read the label myself, but in case anyone here already knows...) does it affect rate of "grime" buildup on the windows? i'm assuming it should be reapplied after the windows are cleaned.
Hawke
Post by Hawke »
quote:in that specific situation (wet and cold outside), it seemed like the windows defogged faster with the recirculate on. i actually only tried it after having read on some thread here that recirculate ON would defog more effectively. the fogging and the air moisture scenario do make sense. what are other ways to deal with this that have been effective?DO NOT USE RECIRC! The idea is to remove the moisture from inside your vehicle and the windows will clear up. Recirc doesn't do this! Also turn the A/C on and that will help remove moisture as well. I'm not sure if defog mode automatically turns it on, I know defrost does though. So for best performance, don't use recirc and use the A/C.
kaybeejay
Post by kaybeejay »
Try keeping your windows clean of grease and dirt. I have the window deflectors and so I can open the windows a crack (even if its raining) and that keeps ALOT of fresh air coming into my Vibe. That keeps the windows very clear.
2003 Shadow Vibe GT and 2001 Nissan Xterra 4x4
vibe owner
Post by vibe owner »
No one has linked to the prior thread: http://forums.genvibe.com/zerothread?id=2119 As I explained on page 2 of this thread, your air conditioner is on even though you didn't turn it on -- it is on anytime you select defrost and the outside temperature is much above freezing. Often this helps remove fog, but under certain circumstances it can make fog worse. I disconnected the feature so my A/C is only on when I want it to be and I'm happy with the results.Unless you are in a tropical rain storm, don't try to defog the windows while in recirculate mode. Your breath is the worst source of humidity as long as you are warmer than the windows. (People who don't understand this are the reason the stupid automatic A/C feature was put in.)
Vibe Rater
Post by Vibe Rater »
Just a thought. Any of you guys (or gals) that have trouble with fogging windows in your VIBES, do you smoke in your car? Tobacco smoke leaves a residue on the glass (and everything else) that may worsen the problem.
