Engine cover removal
Emerica13
Post by Emerica13 »
I'm trying to take off the engine cover to clean and just because ive never looked around in there, but none of my sockets will fit the bolts. Ive determind its somewhere around 3/8 but it seems my 3/8 socket is too small, and my 7/16 is too big...help?
2003 Shadow Vibe GT
Mrizzle05
Post by Mrizzle05 »
I havent taken mine off to paint it yet... but try using MM sockets to see if those will fit?
Psychobroker
Re: Engine cover removal (Emerica13)
Post by Psychobroker »
I thought it was a standard 10mm?
Atomb
Re: Engine cover removal (Psychobroker)
Post by Atomb »
Quote, originally posted by Psychobroker »I thought it was a standard 10mm?that would put it right between the 3/8 and the 7/16!
Emerica13
Re: Engine cover removal (Atomb)
Post by Emerica13 »
Quote, originally posted by Atomb »that would put it right between the 3/8 and the 7/16! lol thanks, I wasnt sure if the 3/8 wasnt fitting just cause of some rust buildup on the head or if it was in fact the wrong size. Thanks for the help, I'll go out and buy some metric sockets tonight or tomorrow and give it another try.
2003 Shadow Vibe GT
Lancer
Post by Lancer »
I always leave the 10mm ratchet in the glove box. You can take apart a lot with just that one size!Remeber it's a Toyota made car. All metric!
Mrizzle05
Post by Mrizzle05 »
Well cool now i know what i need... and i read that the clips in the back just pop out. not easily im sure!
Lancer
Re: Engine cover removal (Mrizzle05)
Post by Lancer »
Oh yeah, the clips. Hehehe! $5 days you break them! They break VERY easily so be careful.
Emerica13
Re: Engine cover removal (Lancer)
Post by Emerica13 »
Are the clips essential? I mean, if I break them, do I have to replace them? Or is it not a big deal?
2003 Shadow Vibe GT
I broke the clips on mine, somewhere about 70,000 miles ago. I'm gonna get new ones one of these days
Mrizzle05
Re: Engine cover removal (joatmon)
Post by Mrizzle05 »
Quote, originally posted by joatmon »I broke the clips on mine, somewhere about 70,000 miles ago. I'm gonna get new ones one of these daysSoooo... we take it there not essential.
MAVibe
Post by MAVibe »
nope. broke mine first time removing the cover.
HISTORY:2006, debadged, Cosmo Racing SR, Megan Racing strut bar, Progress swaybar, custom VVT-I body decals, GrafxWerx engine cover overlay, front-end bra, WeatherTech visors, S2000 antenna, f&r mudflaps, roof spoiler, AND MODA R9's w/ 225/40/18 Yokohama Avid's....
damronjr
Post by damronjr »
Quote, originally posted by Lancer »I always leave the 10mm ratchet in the glove box. You can take apart a lot with just that one size!Remeber it's a Toyota made car. All metric!10, 12, and 14mm and you can almost take apart the whole car!
Mrizzle05
Post by Mrizzle05 »
Hey, when you guys painted your engine covers did you use a regular primer or is there a high heat primer... or no primer at all???
Emerica13
Re: (Mrizzle05)
Post by Emerica13 »
Quote, originally posted by Mrizzle05 »Hey, when you guys painted your engine covers did you use a regular primer or is there a high heat primer... or no primer at all???That was my next question lol
2003 Shadow Vibe GT
MAVibe
Re: (Emerica13)
Post by MAVibe »
As a professional painter, it can never hurt to use a primer. The standard existing engine cover will have a factory finish to it- to protect it. The primer will etch into it and provide a proper surface for the finish paint to adhere to.Your best bet--- scuff up the finish, by hand, on the existing cover w/ an 80 grit or less sandpaper. Clean the cover!(very important). Then prime it. Make sure you choose a primer that specifies coverage on plastics. Then finish coat it. Two-three coats will assure optimal results.
Clips? The dealer broke mine off. Not essential. Nor are the nuts essential really, I forgot to tighten mine down sufficiently when I changed the plugs and lost both of 'em. it stays on. The dealer ended up puting two standard ol' nuts on there when they replaced the transmission, I guess they thought they lost the nuts.
