A GT header might work. A GTS header will not work.A stock GT header won't give you much.You would get more hp if you ported your own stock header.Here is some info on porting your header from NewCelica.org:http://www.newcelica.org/forum...eader
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
Quote, originally posted by BlueCrush »A GT header might work. A GTS header will not work.A stock GT header won't give you much.You would get more hp if you ported your own stock header.Here is some info on porting your header from NewCelica.org:http://www.newcelica.org/forum...eaderThat link is what I've been looking for, Thanks
They make nice aftermarket header's for the base Vibe. Don't do what I did and get a aftermarket or stock header that was made for the celica gt! They wont have the O2 sensor bung, and the end of the collector bends slightly to the drivers side and I've been having a lot of problems with exhaust leakage.
Go to http://www.neverenuf.com or give him a call (Brad) he should be able to help you out with a header and tell you what will fit. The header will give you 1-4 extra HP. Check out my cardomain page to read the dyno results.http://www.cardomain.com/ride/2290660
