2005 moons and tunes owners question
qwerty1
Post by qwerty1 »
Could you guys help me out? I would like to know from all the 2005 base vibe moons and tunes package owners if yours came with a indash 6 disic changer or not? I just bought my vibe used last week and could of swore that the car had the six disc the day before I bought but it only has a single in it right now. The moons and tunes is the only real package it has so I figure I should check to see if it was part of the package or not. The dealer told me that the indash was not availble in 2005, but my owners manual, and my memory tells me it did. I cannot imagine that they would swap it on me but I can't stop thinking about it. Please help!!!!!
BlueCrush
Re: 2005 moons and tunes owners question (qwerty1)
Post by BlueCrush »
Mine is only a single.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
4X4CHICHI
Re: 2005 moons and tunes owners question (BlueCrush)
Post by 4X4CHICHI »
Mine is a single with XMRadio
2004 FUSION ORANGE VIBE GT200 Watt CD & XM radio, Tinted windows17" Black Casino'sSilverstars Head and Fog, Injen C.A.I.http://www.cardomain.com/memberpage/453424
GMJAP
Post by GMJAP »
Quote, originally posted by qwerty1 »Could you guys help me out? I would like to know from all the 2005 base vibe moons and tunes package owners if yours came with a indash 6 disic changer or not? I just bought my vibe used last week and could of swore that the car had the six disc the day before I bought but it only has a single in it right now. The moons and tunes is the only real package it has so I figure I should check to see if it was part of the package or not. The dealer told me that the indash was not availble in 2005, but my owners manual, and my memory tells me it did. I cannot imagine that they would swap it on me but I can't stop thinking about it. Please help!!!!!The 2005 M&Ts comes with a 1CD. There were 4 packages as I recall:Base with 1CDupgraded with 6CD & tweetersM&Ts with amp and 1CDDVD nav with remote 6CD changer.Note that you can usually pick a 6CD dash unit off Ebay for about $100 to $150. Any model year Vibe 6CD or 03/04 Matrix unit will work, but don't get one from a different GM vehicle.I got one off Ebay from an 04 Matrix and put it in my Dad's 2005 with M&Ts no problem. Works fine and sounds great.
rlfreese
Post by rlfreese »
yeah,mine was one cd then ireplaced with kenwood excelon
2005 Base Vibe W/ moon and tunes , piaa headlight/foglight bulbs, tein s-tech suspension, cosmo CAI, TRD quickshifter, ES motor mount bushings, magnaflow exhaust, RK sport CF roof rack caps, tinted windows, kenwood KDC-X589 HU/w remote Cardomain Page http://www.cardomain.com/ride/797307
rocket9005
Post by rocket9005 »
I would forget the changer, and opt for a plug or an adapter for an I-pod. Alot more music that a 6 disc changer, and if you do get the I-pod adapter you wouldn't be able to use that changer anyway.
2005 Base Vibe, 5 spd, NeptuneMoon & TunesPower Windows & Door LocksAlloy WheelsStill No mods (yet)
Correct me if I'm wrong folks, but couldn't you get either? You could order the moon & tunes which comes by default with the single disc stereo, but you did have the option of upgrading the stereo to the 6-disc.If you think you saw a six disc in there, it's pretty easy to find out whether you should have one and somebody did the ol' switcharoo on you before you got the car. Open the glove box and have a look at the service parts identification label, that will show everything the car originally came equipped with.Only bad thing, I don't see an RPO code for the 2005 Vibe. I don't know how the codes changed over the years, perhaps someone can verify what RPO codes the single and six disc units had for 2005. You can find the breakdown of the 2003 cars here. They may still be the same with the 2005 but I'm not sure since there were changes with the audio system for that year, maybe someone can verify that...An '03 would probably show something like UC6 - AM/FM/CD/W In Dash 6 Disc CD Changer/4 Speakersand then UZ6 - Premium 6-Speaker SystemHope this helps!
qwerty1
Re: (rlfreese)
Post by qwerty1 »
So you say the 6 disic upgrade included tweeters, are they the ones on the top part of the door by the window? If so then I have them. I wonder then if it was possible to have them w/o 6 disic??
Re: (qwerty1)
Sure is possible to have 'em without the six disc. 2003-2004 Moon & Tunes package came with six speakers - two in the rear doors, four in the front - including the two tweeters at the top. For 2005 it went to seven speakers with a sub in the right rear of the cargo area. All had a 200 watt amp under the passenger's seat up front.You could have either the single disc or six disc changer with this package, I'm pretty sure.
qwerty1
Re: (ColonelPanic)
Post by qwerty1 »
I kind of thought that might be the case, oh well can't blame me of asking.
Re: (qwerty1)
Never hurts to ask!!
qwerty1
RPO 2005
Post by qwerty1 »
The RPO's are the way to go. I never even knew they were there, thanks guys. So all I need now is a list for the 2005, and I will be able to put this all behind me. Anybody happen to know them?
Jaxy
Post by Jaxy »
Mine came with in dash 6-disc changer and 6 speakers.
2005 Base Platinum, Tinted WindowsLeather Seats, Moon & Tunes, Power Pkgde-badged
qwerty1
Re: 2005 moons and tunes owners question (Jaxy)
Post by qwerty1 »
Hey jaxy, since yours come with the six disk. Is it possible for you check the RPO in the glove box and post the ones with the U in front of the number? I have to check mine again I don't remember what there were, but I am told they are the ones that deal with the radio section. Thanks
