I assume you have an 06 gt? It looks like a replica of the K&N system.Yes it will fit, but you will need to do something about the air pump. On my 06 Rolla XRS, I bought 3 feet of 3/4" rubber hose and a small filter to fit the end of the hose. I connected that to the air pump port (after removing the air pump filterbox) and routed the hose up into the engine compartment behind the headlight. You will also need a little cap to plug up the ODB port on the back of the intake. 05+ 2zz engines don't use that.
