well, the doc I have says there are two red/yellow wires on the headlight control switch, but I haven't taken my car apart to verify.have separate pdfs for headlight and fog lightheadlight doc is at
http://forums.genvibe.com/zerofile/9337/017hl.pdfbelow is foglight docI guess if you want to never use the turn signal switch for hi/low switching, you could just tap in to the signal coming out of the DRL module that controls the dimmer relay, (
http://forums.genvibe.com/zerofile/9337/017hl.pdf shows it as a white/red wire) and ground it when you want high beams. Maybe cut that wire and have a switch that grounds the relay side. I don't know how the DRL module controls various things at various stages, it you just ground that wire to the dimmer relay it could mean that you would only be able to turn off the high beams using the foot switch, even if you let the car automatically turn the headlighs on/off, puts more risk of leaving the headlights on accidentally and draining the battery. Sorry I can't say exactly what to do, I don't plan on doing the mod to my car. Maybe some of the wiring wizards will chime in with advice.
Attached files 018ffl.pdf (24.7 KB)
