Got my GF a Ipod and a FM transmitter... as expected it sounds like garbage, but I haven't found any other options with her existing setup...I have a midend sony headunit I pulled from a different car that has a aux input on the front and plays mp3s, I *thought* about installing this in her car but it would probably not sound as good as the factory deck huh? (vibe runs an amp right?)what can i do
-2008 Corvette Coupe MN6, tuned & tinted... more mods to follow-2007 Mazda3 S-touring hatchback 5spd AUTO, stock & tinted. GF's-2003 Pontiac Vibe base AUTO, stock and winter duty (185k miles)gone but not forgotton...02 Z06, 04 & 05 STi, 93 & 94 RX-7 TT, 89&90&91 Audi 80/90, 02 A4
umm.. it's crazy late, so mond the speel errors. there is a aux adapter for the moons and tunes radio. if i rememebr correctly, the adapter is only good for 04 and up models. so an 03... out of luck. rty the search engine here. look for aux.i also beleive there is a transmiter taht goes in line with the antenna. it doesn't use a fm modulator. sound is better than over airways. if you want crystal clear sound from the ipod, than an aftermarket radio is needed. one with aux inputs.again try the search and look for ipod. alot of those topics have come by recently.
Actually the one in line with the antenna is still an FM modulator; it just sends its signal directly to the antenna so the sound is clear with no interference.
The only options for 2003 1CD, or any year 6CD, is a transmitter or modulator.Some people have gotten good quality audio from a decent modulator (like Kari).Aftermarket HU's can be gotten to work well with the factory amp. A line level converter is often needed. Search around for some posts on the topic.
